Current driver/power amp for solenoid
L
Lyndon
Hi all,
I have a large solenoid that draws a maximum of 15A at 24V. I want to
be able to vary the current flowing into the solenoid so I can vary
the force it generates. I want this to be driven by DAC that has an
output voltage of 0-5V and minimal sourcing current ~100mA.
I've been thinking about power FET's or a BJT's but I haven't got much
experience in this sort of electronics so I really can't take it any
further. This system is all part of a feedback pedal design that will
provide more resitance the further you push in the pedal. We have a
potentiometer measuring pedal displacement and this goes into a
microcontroller, through a simple transfer function and produces the
output signal which will drive the solenoid. I'm stuck with the type
of current driver or amp I should use. Any advice, or links to
circuits etc., will be of great assistance.
Thanks,
Lyndon.
W
Winfield Hill
Rob wrote...
Lyndon wrote ...
Lyndon - have you considered using a PWM motor controller? For a
quick test Dick Smith do a $20, 20A controller which I think is
PWMable. Perhaps others may be able to expand on this approach.
I wonder if Lyndon wouldn't be better off with a geared-down motor
i torque mode rather than a solenoid. They have rather poor force
vs. displacement characteristics, whereas motors are excellent.
Thanks,
- Win
whill_at_picovolt-dot-com (use hill_at_rowland-dot-org for now)
W
Winston
Winfield said:
Rob wrote...
Lyndon, do you really only need pedal resistance to increase linearly
between 15% and 85% of displacement? A compression spring on your pedal
would automatically do the math and provide the proper resistance.
http://www.asraymond.com/spec/faq.asp
--Winston
Rob
Lyndon said:
Hi all,
Thanks,
Lyndon.
Lyndon - have you considered using a PWM motor controller? For a quick test
Dick Smith do a $20, 20A controller which I think is PWMable. Perhaps others
regards
rob
Richard Freeman
Why do a simple solution when a much more complex one is (not) available ?
Rob
--Winston
Good point - a company here that makes training simulators uses this method
sometimes in combination with rubber "bumpers".
For accellerators/throttles springs of various compression rates are stacked
on on top of the other to enhance the progressive feel. For brake pedals
rubber bumbers of different diameters / lengths are stacked up to give a
realistic feeling pedal.
This is of course irrelevant if you do need the electronic solution for
other reasons.
rob
