Current Development Status of Image Recognition SW
K
Klaus Kragelund
Hi
Just for fun, looking into a DIY project, but which could spin off to a commercial product, I am looking into image recognition.
For the application I would need the unit to recognize an object. The reference object would be stored in a database with a picture from different angles, and the SW would compare an observed picture to the reference images and product a percentage match figure.
The image would not be a simple figure, but could be of different sizes andcolors, but with the same fundamental shape. The image could for example be a tree, and the system would need to determine what kind of species it was and report the match figure.
So, knowing little of current developments, it this feasible or would that be 10 years into the future?
NI Labwindows has image recognition SW but I thing it will only cover basicshapes
Google has some advanced function in Google Photos:
http://googlesystem.blogspot.dk/2013/06/how-googles-image-recognition-works..html
But, this is in google´s realm, and they could drop that service from dayto day and that would then be a showstopper
Any insights?
Cheers
Klaus
Martin Riddle
Hi
The image would not be a simple figure, but could be of different sizes and colors, but with the same fundamental shape. The image could for example be a tree, and the system would need to determine what kind of species it was and report the match figure.
NI Labwindows has image recognition SW but I thing it will only cover basic shapes
http://googlesystem.blogspot.dk/2013/06/how-googles-image-recognition-works.html
But, this is in google´s realm, and they could drop that service from day to day and that would then be a showstopper
Any insights?
Cheers
Klaus
Have you looked into OpenCV. Its fairly easy to make a wrapper for
calls from LV. My next project is to update some old LV wrappers to
the latest OpenCV.
<http://opencv.org/>
The original code is from Intel.
Cheers
Tim Williams
Down to the *species*?
The gross morphological differences between phenotypes within a given
species are almost always comparable to the gross differences between
species. Or in other words, just because it's bushy on top and woody on
bottom doesn't tell you what species it is. Let alone other forms, like
some species (more than others) can be trained into, or will naturally grow
in, a bushy or even bonzai shape. To say nothing of arborism, heh.
Tim
Seven Transistor Labs
Electrical Engineering Consultation
Website: http://seventransistorlabs.com
Hi
shapes
Any insights?
Cheers
Klaus
RobertMacy
Any insights?
Cheers
Klaus
There are aps available right now for the blind. Use your android, or
cellphone, to look at an object and it will tell you what the object is.
Jasen Betts
a dude in a callcentre identifies it and tells you (and NSA etc) what it is.
K
Klaus Kragelund
This task is simple. It could take a lot of computing though.
I don't think it classifies as simple, certainly limited material is available and what I have found sofar indicates that the success ratio of the recognition engine is not that impressive
Do you need to match entire object against database or do you have to
split object into components to classify it?
Could be both, but I guess it would be better to have the entire object. If the algoritm splits the task up in smaller images is another matter.
It depends. Basically this is a question of how much computation you can
afford and if there could be shortcuts to reduce computation.
It is for a robot. So I would aquire an image, send it to the server and let the server do data crunching and return with tags describing what is present in the picture. I do not think the function can be embedded into a simple embedded platform.
Very basic and trivial stuff.
What do you really need?
Well, I need a robot to be able to distinguish between different objects, that's the basic function
Cheers
Klaus
