Not sure how this would work. But im sure its possible.
How its setup:
The motorcycle hand controls turn a cable which in turn turns the (TPS) throttle position sensor.
the TPS then tells the ECU how much to open the butterfly valves.
How would I determine the type of output the TPS sends the ECU? I would like to mimic it with a digital potentiometer
or similar system which should effectively let me "lock" the throttle at a specific speed.
I would then like to implement a "cutoff" that once the brakes or clutch is pulled it would turn off.
Here are some pictures of the setup. You can see the TPS attached to the silver bracket that the throttle cables twist.
How its setup:
