John Popelish
Spehro said:A precious-metal RTD changes less than +0.4%/K. Accuracy of the
*sensor* is typically +/-0.3 to +/-0.03K, so you'd normally want an
instrument to be considerably more accurate and stable than that. An
LDR doesn't have a hope in h-e-double-hockeysticks of getting there
unless this is a particularly sloppy & crappy application. The usual
method is to use an active analog/digital circuit.
Best regards,
If the LDR can swing from hundreds of ohms to thousands of
ohms, and you make full use of that range to swing between,
say 100 and 110 ohms, by adding the appropriate parallel and
series resistors, the overall stability will be a lot better
than that of just the LDR, itself. Choosing the best two
resistors for linearity is a least squares fit type math
problem. I do this sort of thing with Mathcad, quite often.
