I have a WTV020 SD card sound module loaded with a single 30 minute audio file that I would like to repeat-play continuously. Although the manual below describes a "loop" mode, I find the wording confusing. It sounds more like a resume after retriggering.
https://dlnmh9ip6v2uc.cloudfront.net/datasheets/Widgets/WTV020SD.pdf
Here is what the manual says on page 10 (cut and pasted).
"7.4.LOOP PLAY AFTER POWER ON After turn on the power, it will play the voice directly, trigger the relative I/O can pause, next trigger will keep playing.In this mode, when the module playing voice 2 and the power was cut off, after turn on power it will play from voice 2 or voice 3(can be customized) Alternative trigger mode: a.Edge tirgger to pause /play b.Level trigger to pause/play."
This refers to the schematic diagrams on pages 21 and 22.
Can someone please explain how this is supposed to work? Or if it is not a proper loop function, what is the simplest circuit I can add to implement one?
