Conduction Angle
I
Irfan
What is conduction angle and how can we measure it. I am using
Microelectronics by Sedra Smith 5e. I am not clear about this concept
and couldn't find any resource on the web also.
Kindly explain it to me.
Thanks in advance!
Irfan
Bob Myers
Consider that each full cycle of a sinusoidal waveform may
be considered as "360 degrees" of that wave.
With that established, the fraction of the wave period in
which a given active device is conducting (or otherwise
doing its thing, e.g., amplifying the signal) may be expressed
in terms of degrees. For instance, if you pass a sinusoid
through an ideal (no forward drop) diode, you could say that
the diode (since it passes exactly half the wave) has a
"conduction angle" of 180 degrees.
Bob M.
