hi! this is my first post, and i'm hoping you all can help me with a project.
i'm making a nerf pistol from scratch, since hasbro hasn't made a semi-automatic or fully-automatic clip-fed pistol yet. i'm handy with the physical building part, but i need help with the simple electronics.
the pistol will have two components. the main component will be a pair of high-rpm drive motors rotating in opposite directions, exactly the same as a pitching machine. the other component will be a much smaller and slower rpm motor that feeds the darts into the drive motors.
i'd like to power the whole pistol with a pair of trustfire 14500 3.7v 900mAh batteries in the handle. the motors don't need to have a variable speed setting, since they'll be hardwired to be either on or off at their respective speeds.
so, here are my questions:
1) how would i split the power from the batteries to the two different components? would it be as simple as running two positive wires from the + pole and two negative wires from the - pole?
2) how would i power both drive motors simultaneously? just split the wires?
3) how do i control the speed of the three motors as simply as possible? would i use a resistor in the wire leading from the battery to each motor? if so, how would i calculate the RPM of the motor to tell me what resistor (or whatever component i need to actually use) to use?
4) (bonus) is there a way to easily create a momentary circuit, where one press of the trigger cycles the feed motor a certain amount of time and then stops (unless the trigger is still pressed)? this last part is probably less simple than i would hope, so i might just be stuck letting go of the trigger at "just the right time" to stop it from feeding more darts into the drive motors.
thank you all very much in advance for any help you can offer!
