Thanks,
That's in reference to R (resistance) and not reactance, right? So if I
only have 22 ohms resistance and 70000 ohms reactance and gain of 100
then the total output voltage noise would equal thermal noise of the 22
ohm resister, which would be
Vn = sqrt(4 k T B 22) * 100 = 60 nV/SqrtHz
Darn, that's noisier than I thought it would be.
Paul
The reactance doesn't contribute noise.
Originally, I thought you were talking about the equivalent input noise
voltage of the JFET itself, as quoted on the manufacturer's datasheet. This
will contribute more noise than your 22-ohm resistor. For a 2N3819 it's
about 6nV/sqrt(Hz).
Input noise due to 22-ohm resistor = 0.6e-9
e_n for JFET = 6e-9
Total input noise = sqrt(0.6*0.6 + 6*6) = 6.03 nV/sqrt(Hz)
Ouput noise = 603 nV/sqrt(Hz)
