Your drawing shows
two horn tweeters wired in series and also connected in series with a 12 Ω, 10 W, resistor and a 4.7 μF, 100 V, capacitor. Is this correct?
At 1000 Hz (the typical minimum frequency for a "tweeter") the RC network presents an impedance of about 36 Ω. At 20,000 Hz the network impedance drops to 12 Ω. The total impedance at 1 kHz would then be 44 Ω to 56 Ω, falling to 20 Ω to 28 Ω at 20 kHz. How can a single horn tweeter have an impedance of both 4 Ω and 8 Ω that sums to either 8 Ω or 16Ω when two are connected in series? Answer: it can't.
Who knows what the "actual" speaker impedance is? All that label means is the tweeter can be driven from an amplifier providing either 4 Ω or 8 Ω source impedance to a level of 750 watts without total destruction (titanium is wonderful stuff, right?). What does than even mean? Is that 750 watts for-real rms power or some hokey marketing hype "music power" inflated over rms power by a factor of two or four or whatever the market will bear?
Let's be conservative and assume it means real rms power. And let's assume the amp has 4 Ω source driving impedance. Then to drive that tweeter with 750 watts requires P = I²Z, or I = √(750/4) A = 13.7 A. Hmm. If that much current must flow through a 12 Ω resistor to reach the tweeter, then the amp must produce E = I R = (13.7) (12) = 164 V (rms) across the resistor alone and E = I Z = (13.7) (4) = 54 V (rms) across the speaker terminals or a total of 218 V (rms) at the amp output terminals. I don't think there are too many modern solid state amps that will output that kind of voltage. Maybe 54 V directly to the tweeter is possible, but without a BA output transformer and a kilowatt or two of power, I don't think the higher voltages will be obtained. Could be wrong, of course. Haven't played around with audio power amplifiers since the 1970s and then only at hundred watt or so power levels.
The effect of the RC network is to reduce the power available to drive the tweeter at low frequencies by increasing the impedance in series with the tweeter. This is a good idea. You can "play around" with the numbers using an
online RC impedance calculator at this web site. Note that the 4.7 μF capacitor has a reactance of about 33.9 Ω at 1 kHz, so if it was passing 13.7 amperes to drive the tweeter to 750 watts at that frequency, it would have about 464 V rms dropped across it. Not a good idea with the capacitor rated for only 100 V. Probably a good idea not to drive the tweeter with 750 watts at 1 kHz.
Is this speaker system for use on a performance stage to impinge loud sounds on an audience? They make speakers just for that.
