edward.ming.lee@gmail.com
Most especially prototypes made with "non-standard" material, EG:
20mil to 31mil material.
Ideas? References? Approx pricing for 1-2 boards?
0to99, depends on size.
Who? Where? *REFERENCES*?
Thanks for wasting time with NON-information.
Who? Where? *REFERENCES*?0to99, depends on size.
Goddamnit, just give me references and *I* will find out from THEM
what THEIR criteria WRT pricing.
Being an asshole, you would bitch if i required YOU to do screening
(ie: any WORK).
Goddamnit, just give me references and *I* will find out from THEMPCB prototypes everywhere depends on size.
You are welcome. Nondeterminate question get nondeterminate answer.
Excellent!John said:
Just did a online quote on http://www.youpcb.com
10PCS, 10cm by 10 cm, 24mil thickness (0.6mm), it will be $41 shipped (if you are in usa). Cheaper then 1.6mm, I guess the shipping weight is less so it is cheaper.
My micro layout, with via, is bigger than 10x10. Even a 20 pins FPC socket is bigger than 10mm. What else can i put on the 10x10?
Check; found that PcbCart allows a wide range of thicknesses - veryMartin said:I think 31mil is a standard size.
Size and # of Holes needed.
Probably around $500 from the big guys. Less thru the pools.
Cheers
Does anyone know if they will score a panel (V-cut) from the 10cm x 10cm
board ?
I need .7" x 1.1" boards, a 10x10cm panel would hold lots if they will
score the pcb for the same price.
I registered with youpcb.com.I remember I have done it once, but not sure if there are additional cost or not, let me check my orders when I get back home.
