Hey everyone, i am looking into a project that i want to be able to charge a Seiko MS621FE-FL11E lithium coin 3.1v battery.
I will be using the 5v from the USB and convert it to 3.3v using the LM3940. However, i am not sure what all i need between the 3.3v and the battery itself. Is there some type of protection that is needed so that the battery will not explode? I would also like to incorporate an LED that flashes when its charging and also stays lit when charging has completed.
I've been looking at the chip MCP73833 but it looks to output (charge) with 3.7v. If that is ok to use with the 3.1v battery itself then i can omit the LM3940 and just use the MCP73833 chip with 5v to the output (charging) of 3.7v to the battery. It also has output for LED's to show status! Sound good?
Any help would be great!
David
David
