Change HD & Power leds
John
I would like to change the led's in a old pc I recovered amber=power
green=hd from there factory color to different colors like blue and super
red led's.
I use to play electronic hobbies years ago so I’m concerned that if I
just solder the defferent color led’s to the leads I might fry
something.
Any help welcome
John
super red led's.
something.
Any help welcome
Sorry amber is HD and green is power.
Jasen Betts
red led's.
something.
powersupply for the existing LEDs is most probably 5V through a series
resistor, so just replacing the leds should work. the new leds may not
light to full brightness but will probably look good none-the-less.
There's no risk of damage to the PC by this modification as long as you
take due care.
Jasen Betts
what can go wrong?
He needs to _know_ what the supply voltage is and the Vf and If of the
LEDs he wants to use before he can proceed with the modification
intelligently.
we're talking PC assembly here, intelligence isn't really needed :)
the motherboard already has resistors for the existing LEDs changing
in higher voltage LEDs isn't going to damage anything.
Bad advice.
intelligently.
JF
Actually it was good advice. They are current limited already, within
the typical sub-20mA range as with any other 100mW encapsulated LED.
This is a necessary design parameter for motherboards. You can blindly
grab a similar looking LED and hook it up to any motherboard without
issue, and indeed that is exactly what happens when you install your
choice of motherboard into a computer case.
The intelligent data collection choice is significant if a mistake
would take a great deal of time or expense if things went wrong, which
it won't, or if there was nothing yet known about motherboard
circuitry, which there is.
