Hi I have a cheap ebay plasma globe, and it never worked from day 1 but it was too late/expensive to complain. Later I opened it up and added a 470uF that was written on the PCB but missing from near the HV transformer.
Its meant to run off a 12V-AC transformer, and it has the bridge rectifier on the PG PCB. I can't find the wall transformer and so just tried 12V-DC right onto the main 220uF filter cap and it worked (there is no XY caps or any such things or a fuse I should add a fuse). I never did find its PCB schematic or for another for that matter
So today I took out the 4 diodes, and I'm just running it of a proper AC-DC wall trans with 12V 2A DC output (from a quality fibreOP modem) that fits the plug right
If 12V rms goes into a 4x 1n4001 rectifier, what DC voltage comes out ? I skimmed through this
So if I follow,
Vmax = 12rms / 0.707 = 17V and then Vdc = 0.637 * 17V = 10.8V
and then I'm supposed to take of another 1.4V for 2 diodes
=9.4V at the 1st filter cap ? (there is no XY caps or any such things) it was just the 4way and then a 220uF filter cap.
Does that sound right ? If so straight up 12V is way too high right ?
I never owed a PG before and don't remember so much the heat on the plastic, this seemed pretty hot, and something whines a bit . So I only ran it for a minute, but with it all closed up, no idea if anything inside is overheating and what not. (and its bedtime)
So if I follow,
