Capacitors for RF ground
Michael Porter
Can anyone (Larry?, Bruce?) help with a spec for capacitors for RF
ground for a HF radio? I want to keep the DC away from the (aluminum)
boat.Thanks,
Michael Porter
Michael Porter Marine Design
mporter at mp-marine dot com
www.mp-marine.com
Bruce
boat.Thanks,
Michael Porter
www.mp-marine.com
I did look into capacitor grounding some time ago and whoever I talked
to said shove a bunch of capacitors in parallel into the system. This
was based on having enough parallel capacitors to carry the signal
amperage as well as voltage. I asked whether impedance was important
and was told "probably not as long as you have enough capacitance."
Larry will probably have more to say on the subject....
Cheers,
Bruce
Bruce in alaska
boat.Thanks,
Michael Porter
www.mp-marine.com
You need to define the Frequency Range of the Radio/Antenna System, and
Power Output, that your trying to DC Isolate/AC Couple. If your dealing
with just HF Frequencies (3-30 Mhz) and less than 150 Watts PEP, it is
very easy to get a .5uf non-Polarized 600 Volt Cap, to do the job. As
you Lower the Frequency, and or Raise the Power Level, you will need
larger Capacitance and Higher Voltage Ratings. The whole idea here is to
have the Capacitor be as low of impedance, as possible, at the Lowest
Frequency of the System, and the highest Voltage Rating available which
will allow the Highest Power Level.
L
Larry
boat.Thanks,
Michael Porter
www.mp-marine.com
Hmm....Let's assume you have a vertical antenna like a Shakespeare or
insulated backstay or just a longwire strung between some masts.
When the antenna is near 1/4 wave resonance, its feedpoint impedance
gets very low, somewhere around 15-20 ohms. Using simple math:
P = I squared R so I, the current in the antenna and ground system,
equals the square root of P, 150 watt marine radio divided by R, the 15
ohms or even lower with your nice metal grounded hull.
This capacitor is in series with this current from the ground on the
tuner to the nicely grounded hull. Doing the math you get a hair over 3
AMPS of RF current going through that cap at 150 watts. This CURRENT is
the problem. Simple cheap capacitors, with their little wire leads just
touching the plates in a cheap cap, simply cannot handle this kind of RF
current flowing in them. The caps get hot from the resistance of the RF
current flowing through their tin foil plates and will eventually fail,
probably shorting out as they melt the dielectric so you won't even
notice it...shorting ground to the hull isn't certain death, won't blow
fuses.
So, we SHOULD, to be fair, use an RF capacitor that can handle at LEAST
4-5 Amps of RF current....a transmitting capacitor.....Strike ONE....
Now, this series capacitance in series with such a low impedance at or
near resonance (worst case scenario for the series cap) requires us to
have a very LOW capacitive reactance so the cap acts like a virtual
short to the RF, while acting like an open to the DC you're rightly
worried over...galvanics. So, capacitive reactance is equal to 1/2piFC
the bigger the C, the lower the capacitive reactance, the better it will
work. We don't want this capacitor to be part of the tuning solution,
we want it to act like an RF short. Your lowest frequency, the F in the
equation is around 2 Mhz, if you use the old marine band (again worst
case scenario). So the Xc (capacitive reactance) should be much less
than (I like less than 10% of) that 15 ohms or 1.5 ohms at 2 Mhz.
Filling in the blanks and solving we get about .05 microfarads. There
won't be any appreciable voltage across this capacitor so almost any
voltage rating will do as they are normally quite high voltage
transmitting caps. .05uF or bigger capacitance and 5 Amps are what
we're looking for....round numbers.
About the cheapest place I know of to get real transmitting caps is
Surplus Sales of Nebraska, who specialized for years in the military's
mistakes and pork barrel purchasing but has become more than just a ham
junk store more recently. They do have lots of great RF stuff real ham
operators love. The caps in question are here:
http://www.surplussales.com/Capacitors/Trans_Coup_Caps/cap_trans.html
The most bang for the buck for what we're looking for is the 2nd cap up
from the bottom of this webpage on the right hand side.
..22 uF at 2500 VDC, easily big enough in capacitance to provide a really
low capacitive reactance.
16 AMPS rated...much more than we really need in this application for
safe operation at 150 watts.
But, alas, at $49, if you'll compare to any other caps you'll find the
most bang for the buck....easily fitting our needs for CURRENT and
CAPACITANCE.
The $18 one just to the left of it would work at .001uF if we never used
a frequency below 8 or 10 Mhz....but that's not realistic. More of them
in parallel would work fine, but the costs are higher than the .22 at
$49.
The .22 looks like it would be very easy to drill a hole into a
convenient frame member and bolt the cap solid to the metal frame, then
use two big flatwashers to the bolt on the other end to hook the tuner
ground strap to for best low resistance connection. Do coat both ends
in heavy grease before you're done to protect these irreplaceable bolts
from the bilge water corrosion in the swamp. Grease 'em good and
they'll be fine for many years.
Oh, and please find a place where you can bolt the cap so that the
mounting bolt that's holding it to the hull is on the BOTTOM, or TOP,
preferably the bottom so the cap is sitting upright on top of its
mounting...NOT hanging out sideways with the weight of the cap always
torquing on the bolt trying to pull it out of the cap....not good....
Biggest bang for the buck.
Now, we'll hear a huge blast of noise from all those using 49 cent
ceramic orange drop ceramics with the tiny wire leads. My reasoning and
logic comes from being around broadcast AM all these years....where some
really HUGE EXPENSIVE capacitors are just waiting for the 50,000 watt
blowtorch transmitter to make them into a BOMB!.....always great fun!
.....60 amps or so into a 15 ohm vertical tower 1/4 wave high.
Those capacitors are simply HUGE!
Bruce in alaska
Biggest I ever saw were part of a computer power supply. About three
by ten inches. One Farad at low volts.
Casady
Not the same animal..... RF Caps like Larry is talking about are
NON-Electrolytic NON-Polarized......
L
Larry
[email protected] (Richard Casady) wrote in
Casady
Most computerized music instruments use a 1Farad 5V tiny little button of
an electrolytic capacitor in them, instead of a big button battery that
leaks, any more. It can't provide current, but will stay charged when the
unit is unplugged for months, supporting the static memory the
registrations are stored in so you don't need to reload them.
But, you're talking about DC power supplies, not RF coupling. RF current
through a capacitor is a whole nother ball game!
L
Larry
.....with very low series inductance...virtually none.
L
Larry
When I was a kid we had an electrolytic, rather three in the same can.
We paralleled them, twisted three wires together solder, repeat.
We would charge it up with a 90 volt battery and kill guppies. The
leads were 3/4 in apart and we would straddle the fish with the leads.
Also blew holes in aluminum foil. I caught a friend of my kid brother
about to put the leads in a wall socket. Should have let him do it.
Casady
I had a massive, high-current electrolytic with battery-sized ears sticking
out the top of it to connect to bus bars....a real brute. It was something
like 1.2 Farads at 250 volts, but I can't remember exactly. It's very
unusual for that voltage to be so much capacitance.
Charging it up to 200 volts took many minutes as the power supplies
available had limited current capabilities. Once charge, this beast was
straight from hell. Discharging it across a steel bar welded it solid to
the bar with a bang that could empty the electronics shop...(c;]
L
Larry
Casady
http://cleantech.com/news/3174/eestors-weir-speaks-about-ultracapacitor-
milestone
Wait until you see the massive ultracapacitor EEStor is making for the Zenn
Canadian electric cars. Given enough power, it will recharge in seconds,
not hours, as no chemical battery will be involved. The target is 125
miles at 80 mph all electric. Amazing technology coming....
