Joerg
John said:OK, I admit I've had too much beer, Maredsous and then Stella, both on
draft, but I can't see how a diode helps either problem.
I had a Spaten Optimator (lotsa volts ...) and then a Huebsch Maerzen.
The 2nd diode goes from cap to VCC so it will never allow VCC to be more
than a diode drop below the cap voltage. Whether that's enough needs to
be investigated but it should take the brunt of the current. You
normally need to go one diode drop above VCC and then some (to generate
a current) to trigger the parasitic SCR and since there is the other
half of the double-diode between cap and output that can't really happen
with any serious current anymore. Now one would have to know what the
SCR trigger current is since the family guide only talks about yanking
outputs the opposite direction, not beyond a rail.
