iron core, μ=100
diameter 1 cm
length 10 cm
No of trurns=100
You get 0.99mH (put the values in the calc. and check).
Note:
1. the wire is 10/100=1mm thick.
2. you can play with the diameter,length and turns to get the same results in other sizes.
iron core, μ=100
diameter 1 cm
length 10 cm
No of trurns=100
Note:
