John Miller
Voice said:Isn't it 60khz though? These clocks don't work off the 10-15-20 MHz bands,
do they? I thought they used a loop antenna inside.
Yes, that's right.
DaveM said:WWVB at 60Khz is a ground wave over the coverage area. That's why a VLF
frequency was chosen for the broadcast. Typically, frequencies below 1 MHz
are not reflected by the ionosphere. Propagation is best at night because
the D-Layer of the ionosphere is heavily ionized during daytime hours by the
sun, and causes heavy absorption of the radio energy. Since the sun's
effects are minimal at nighttime, the broadcast signal is least absorbed,
increasing signal strength over the area of coverage.
Dave M
MasonDG44 at comcast dot net (Just substitute the appropriate characters in
the address)
Never take a laxative and a sleeping pill at the same time!!
I live in Houston and bought one of the cheap "Atomic Clocks" at the drugstore.I dished out 50 bucks for a radio controlled (projection) clock from
"The Sharper Image" and I have to say I'm kind of disappointed. I
waited for over an hour during initial setup and tried moving it to a
thousand different locations and different orientations and the closest
I could get to receiving a signal was a blinking tower for no longer
than 2 minutes. I've even turned of my LCD monitor, wireless phones,
bluetooth transmitter and still it does not receive the signal. I've
given in and have set it manually but the unit is still supposed to
check every night at 12 and I will wait and see if it will actually
synchronize (ever).
I am not really aware of the technical details but I did read that "The
LF signal propagates by groundwave, following the curvature of the
earth; the HF signal propagates by skywave, and bounces off the
ionosphere. All signals travel at the speed of light." from
http://www.boulder.nist.gov/timefreq/stations/overview.html
Which I must honestly say confuses me even more...How come there is
mention of two signals? Does that mean the information is simulcasted?
So you use an electrically-shielded loop antenna.
Knowing that the WWVB bounces their signal off the ionosphere
Nice big chunk of ferrite's good.
How the hell do they get antennas that work inside those radiocode wrist
watches? Do they craftily use the strap?
I've had all kinds of problems with mine too, and I live in Denver, fer
pete's sake!
(This clock has taken up more of my time than I'd have expected...)
Jim Thompson said:I don't know, but wouldn't surprise me.
Me, I wear a $20 Timex, that I sync to NIST about once-a-month.
Usually out no more than 4 seconds.
That's the frustrating thing, I have an atomic watch and it never fails to
synch right, but that Atomix clock in my room will unsynch all the time and
I can only keep it in one place in the room for it to work most of the
time, I can't even hang it on the wall where I want it.
I wear a $120 Bulova. 15 seconds slow since November. I sync it about once
in six months.
About the same accuracy for six times the price
I have a $9.95 walmart watch/stopwatch. It's dead-on accurate.
I wear it about 4 times a year.
Mike Smith said:Return it.
What do you wear the rest of the time? ;-)
