Martik said:
My relay failed and I want to bypass it to ensure the pump is working. Will
this cause any problems? Why is there BOTH a fuse and relay in this circuit?
yes it will cause a problem.
the pump is very capable of generating
more pressure than is needed and should blow the fuse.
you have fuel regulators that operate the
relay, fuses are in line in the event that
for lets say the regulator does not shut off it
then should cause the pump to bind up enough to
blow the fuse.
never put in a fuse larger than what belongs in
the fuel pump line.
the question is, is it your relay that failed?
was it burnt contacts,open coil or maybe the
fuel regulator failed which is also a set of contacts
which can cause erratic operation of your engine
when you need the HP!.
you can for a moment jump the relay just to
listen for the pump on action but do not leave it
that way.
