buying a THD meter
Does anyone have any suggestions for a meter that can test power THD?
The purpose it to test THD on LED drivers.
I see Fluke 43's at $3500. Was hoping for something closer to $1000.
Are you referring to measuring the affect on the mains waveform by the non-resistive load characteristics of (in this case) a LED driver?
Just curious, because all my THD measurements have been on signals rather than power. (This told me a lot).
This seems to be near your price point (and this is even cheaper).
That Schnedir is discontinued, unfortunately.
I should have mentioned we need to test 120v, (277v would be nice, though not essential)
There is a link on that page to the replacement model which is priced identically and operates from 110VAC to 415VAC
You should be able to make this measurement using a current transformer and a personal computer.
Feed the signal into a sound input. Get yourself some audio measurement software and you are in business. Some of this software will provide a nice waveform display on the screen, separate values for each harmonic, etc, as well as the THD.
You could also use a traditional audio harmonic distortion analyzer with the current transformer.
Ted
