K
krw
You wouldnt get away with that in the UK.
You don't get away with humor either. ...or is the dumb donkey your
idea of humor?
krw said:[email protected] says...
A duplex outlet or switch can often be found for $.39. Two pronged
plugs are pennys.
I don't think that there's enough sand on planet earth.![]()
It's surprisingly easy to grab the wrong bit when removing a plug. That's why
the UK plug also has a flared base to discourage such behaviour. The shrouded
pins camer alter.
As I said before, it's not about some crazy idea of 'manliness' supposing it's
smart to engage in risky behaviour, it's simply about good design.
Safety isn't cheap.
Pardon ?
If this is any example, I'm moving to England:
http://www.page3.com/index2.shtml
Regards,
Mike Monett
Safety isn't cheap.
Heck, there's so much sand in northern Africa that if it were spread out,
it would cover the entire Sahara Desert! ;-)
why
shrouded
pins camer alter.
Regards,
Mike Monett
John Larkin said:Right, the British Press is a learned institution.
John
Richard said:Yes, the Nanny State protects you from having to learn how to handle Real
Life.
Richard said:This is not true. It doesn't cost anything at all to PAY ATTENTION TO
WHAT YOU'RE DOING.
krw said:
Homer said:I recollect an electrician (not me!) who was wiring up an extension cord.
First he wired the plug on, then he plugged it in to the outlet and went to
wire on the socket end. He never could explain why!!
Truly bizarre.
sort of interesting:At 440 kV, good luck getting close enough to the lines to do anything but
fry.
Big deal. Have you ever worked on a 195 KW TV transmitter, 14 KV
power lines, or even 480 three phase?
Spehro said:
