Hello,
This is my first question and post to this forum, so please do bear with me
I have a Bose Solo 10 sound unit that will not turn on, it's a friends who said it was working fine before than after about an hour or two the system would shutdown. Now I can't seem to get it to power on at all.
The owner said it was working fine until a power outage, which very well could of blown something.
Attached are some high quality photo's of the front and back of the main board. I don't see any noticeable issues, and it doesn't appear to have any blown caps or burnt components. I am thinking that rather large 450V Capcitor [Labeled: C1215] (100UF, EL, 105C, 20%, 450V) could be the issue, but just wanna make sure there is no other glaring items I should check first.
Unfortunately I don't have a Capacitance Meter, looking to get one asap. Willing to take out components and test them if anyone can provide a little assistance. Thanks for your time.
HQ IMAGES AVAILABLE HERE: https://drive.google.com/open?id=1aKhPPMrxDxip2glDUwqHI34cfxHqj8-8
-also uploaded here-
The dis-colorization of the board was cleaned up, which to be thought heat buildup but possibly water damage, can't tell exactly but the board still doesn't work after cleaning up and brushing off any corrosion on any contacts particularly the cage contacts.
(A Cage screws over and under the Power Supply Components)
**Also I have the Service Manual for the unit in PDF, it lists every PCB component which is great to have, check it out(Attached) if you want references to the components I am talking about**
