I tried making a boost converter (as in the pic here:
http://en.wikipedia.org/wiki/Boost_converter ) from a 10V battery pack,
a large inductor (basically, the coil for a 110VAC C-frame motor), a
diode and a 400V 100uF cap.
When manually connecting and disconnecting the coil at say 2-3 times
per second, I was able to get the voltage up to about 100 V. Once I
put a small load on it, though - a 5W night light - the output voltage
dropped considerably.
Then I thought to try something else - have my 100 Hz PWM controller be
the switch. Basically this, but with the inductor in place of the
motor: http://www.cpemma.co.uk/555pwm.html
However, all I got out of it was still 10VDC.
Why would this be?
Is the switching frequency of 100 Hz too high?
What is the typical switching frequency for boost converters, anyway?
I was hoping to get enough juice to run a 5W night light at 100 VDC or
so.
Thanks,
Michael
Why would this be?
so.
Thanks,
Michael
