Bloody digital!
Superman
'King Arthur' on channel 7 is unwatchable! It's constantly pixilating,
although the DVDR says the signal quality and strength is 10! (full
scale) BUT the ads don't pixilate. Now why is that?
rgds,
Pete
http://pw352.blogspot.com
"We stopped the boats coming. The facts speak for themselves. People knew where we stood. We didn't try to be all things to all men. Look, our policy worked. There was no need to alter it" - John Howard
"Our journalists are finally noticing the elephant in the room. Rudd has given us grocery watch, fuel watch, a national dept our children will still be paying, an ETS scheme that will further bankrupt the nation without making an iota of difference to global warming. Rudd is all spin and no substance. Even worse, he expects to fool all people all the time." - media comment
"I don't care what you f__kers think!" - The Hon Kevin Rudd MP, Prime Minister of Australia
atec 7 7
Probably compression particulates > to much compression ?
David Barnett
although the DVDR says the signal quality and strength is 10! (full scale)
I did not watch this movie as I had already seen it on a DVD disc supplied
by my daughter.
I found the movie rather boring.
David L. Jones
Too much compression. They can vary the compression at their end to whatever
they want.
The standard def channels like 7 can really suck. Try watching fast moving
sport action on a standard def channel and you'll see it all the time.
The HD channels are much better and will rarely have this problem. So the
rule is to watch the HD version of the channel (70)unless they are
annoyingly displaying a different show on the HD channel. Even if you don't
have a HD capable TV, it's worth getting a HD box just for this.
It's nothing to do with signal strength, digital TV either works or it
doesn't. If the signal strength is too low to image will freeze, not
pixelate.
Dave.
Superman
supplied by my daughter.
I gave up watching it!
rgds,
Pete
Superman
they want.
Are you talking about artefacts? yes, it's pathetic. we have these hi
res panels and have to watch stuff that looks like it's come off youtube!
I was watching on 70. sorry, I didn't mention that. It was just
hopeless. but there was a storm and lightning last night. perhaps that
was a major cause. but I don't know how we are expected to watch
transmission like this.
Even if you don't
pixelate.
I tried attenuating the signal to see if that helped but it didn't. I've
heard that too strong a signal can cause pixilation and image break up.
rgds,
Pete
Superman
I get pissed off with the audio cutting in and out on live sports progs,
what causes that one ??
It's the same cause as the pixilation- interruption of the digital stream
rgds,
Pete
DaveS
Looked okay on my 1989 TV!
Sylvia Else
Are you using an outdoor antenna?
Sylvia.
Superman
Yes, I have a digital fringe range aerial running into a four way
splitter amplifier. (outer melb metro area location)
And why do the ads not pixilate? There must be some difference in the
nature of the transmission.
rgds,
Pete
Phil Allison
"Rheilly Phoull"
** That was going on a lot at the recent live Golf in Melbourne and Sydney.
The on-course commentators were using back pack portable radio links to the
OB van - which I suspect were not terribly reliable at getting through
obstacles like crowds of people or thick vegetation etc.
...... Phil
Phil Allison
"Superman"
Yes, I have a digital fringe range aerial running into a four way splitter
I was watching on 70. sorry, I didn't mention that. It was just hopeless.
but there was a storm and lightning last night. perhaps that was a major
cause.
** ROTFLMAO !!!
.... Phil
Superman
"Superman"
** ROTFLMAO !!!
I'm glad you're amused. Pity you don't see fit to mention it's cause for
the benefit of our enlightenment.
rgds,
Pete
Superman
Were you watching thru a STB? HD or SD? and what location?
rgds,
Pete
Sylvia Else
I wonder whether that's really the case. Ads occupy less time then
program material (though, admittedly, only half as much), and you'll
probably not be paying that much attention to them. So if they do
pixalate, you might not notice.
But, assuming the difference is real...
The word "pixilate" is used somewhat loosely. Overcompression can create
the situation where one becomes aware of the boundaries of the 16x16
pixel macroblocks, particularly during pans.
A burst of noise can destroy the data so that a number of macroblocks
show manifestly wrong content.
I wonder which of these effects you're noticing.
The difference between ads and King Arthur may be that ads are not down
converted from HD. It's possible there's an incompatibility between
Seven's encoder, and your decoder.
Unless you're using a PVR to watch live broadcasts on a non-digital TV,
you might find a difference between using the PVR to do so, or using the
PVR to record and then play back, and using the digital TV or STB to
watch the broadcasts.
My own experience of digital TV is that it's pretty stable, with visual
glitches rare (less than one per several hours).
Sylvia.
Superman
So your point is (if you actually have one) is that thunderstorms do
seriously affect digital transmissions, right?
..... Phil
rgds,
Pete
Superman
accepted
create the situation where one becomes aware of the boundaries of the
16x16 pixel macroblocks, particularly during pans.
the latter
down converted from HD. It's possible there's an incompatibility
between Seven's encoder, and your decoder.
TV, you might find a difference between using the PVR to do so, or
using the PVR to record and then play back, and using the digital TV
or STB to watch the broadcasts.
I have the current model Panasonic DVDR and recorded it
visual glitches rare (less than one per several hours).
I think location is relevant in that regard.
rgds,
Pete
Phil Allison
"Super Stupid man"
** Errrrrrrr - yes .....
....... Phil
Sylvia Else
Superman said:
the latter
The best bet seems to be that it's a noise issue. Either someone in your
locality (including you yourself) is generating bursts of noise that the
antenna picks up, or mains noise is getting in - perhaps at the splitter
amplifier.
It would be worth checking that the antenna cable screen is properly
connected everywhere.
If the problem is radiated noise from an electric arc, then you'd
probably hear it on an AM radio - particular one that's not tuned to a
station. You could try watchng live TV while such a radio is on, and see
whether there's a correlation between bad video on the TV and noise on
the radio.
Sylvia.
