Good enough for studio quality digital audio to have taken over from
analogue.
Shouldn't do if it is done correctly. The most important thing is to
have an analogue brick wall filter to ensure that no out of band
frequencies reach the input to the ADC. Any timing phase jitter in the
converter will also hurt.
Just a SMOP... But for these volumes of data it requires some skill to
obtain the optimum results for a high dynamic range spectrum
containing a fundamental and a bunch of its near harmonics.
FFT is just a quick way to decompose a signal into its frequency
components. Classical slow DFT would be glacially slow on large
datasets unless you were only looking at a handful of likely
frequencies.
Martin Brown
We've been building FFT analyzers for many years; I can assure you
that ADCs that are very linear do a great job in these analyzers. The
advent of delta-sigma converters made life a lot easier, and of course
for audio they are pretty much universal now. Obviously, if you are
looking for overtones in the spectrum of an excited string, and those
overtones are very close to the frequency of harmonics of the
fundamental, you'll want to know just how much harmonic distortion is
being introduced in the signal path. It can come from the transducer
that goes from acoustic to electrical, and in the amplifiers ahead of
the ADC, and in the ADC itself. It's quite possible to get distortion
in the electrical path lower than -100dBc in the audio range, but it's
also pretty difficult (in my experience) to find hard specs on the
distortion introduced by the acoustic to electrical transducer:
microphone or other pickup. If the overtone and fundamental are both
pure enough tones, and if the harmonics are enough different in
frequency from the overtones, the analyzer can resolve them.
Given a stream of samples from a good audio "card" (or external USB
audio port or whatever), the processor in a modern PC should have no
trouble at all keeping up doing "zooming" and decimating. That makes
the display of the results somewhat easier and the FFT processing can
be done real-time, since you're doing FFTs on relatively small blocks
of data at a slow data rate (after decimation). Does anyone sell
software that actually does all this (nearly) real-time? We used to
do it for audio-range analyzers using a custom ASIC chip set, but
these days, there's certainly plenty of processing power in a typical
PC. We still do it with an ASIC, but now much, much faster.
With respect to determining frequencies, _IF_ I know a priori that I'm
dealing with a pure tone (and therefore stable in phase and
amplitude), and the signal-to-noise ratio is good, I can determine the
frequency to within 0.001Hz with well under 100 seconds of data. The
reason is that I know exactly the response of each FFT point to any
frequency, and the response of a set of FFT points to the waveform can
only have happened with a particular input. It's equivalent, I guess,
to fitting a sinusoid to the digitized points; if I am quite sure the
input is a sinusoid with unknown frequency, phase, amplitude and
perhaps DC offset, I don't need very many samples to nail down those
four unknowns. Of course, the difficulty is that I almost never can
be really SURE that my input is a pure sinusoid. I must also have
enough data points to sufficiently average out whatever noise there
is; thus, a really good SNR allows fewer points to determine the
sinusoid.
You mentioned filtering to avoid aliasing. That's something else that
has been aided a whole lot by the delta sigma converters, since the
sample rate is much higher than the highest input frequency of
interest. The analog filter can be relatively gentle, and the
filtering becomes mainly a digital process; it can be linear phase FIR
filters, which makes corrections somewhat easier, too.
Even when you don't know what the input waveform really is, or when
you know it contains harmonics and overtones and the like, maybe even
multiple "fundamentals," an FFT analyzer can give you a very good
picture of what your signal looks like, spectrally. You do need to
understand things like "windowing" and what happens if your input
frequencies are not integer multiples of 1/(time record length)
though.
Cheers,
Tom
