Harry Dellamano wrote...
terry wrote ...
Hey Terry,
Sounds like we need a simple Cap_Driver box. BNC input, driven by pulse
generator (5V, 1.0uS PW, 100uS RR), our favorite Zeltex PNP/NPN transistors,
10uF MLC, 9V battery and on/off switch. BNC output for scope and pads for
CUT (cap under test). Output R of driver trimmed to 0R50. Those transistors
should pump +/- 10Amps, <10nS rise and fall. We could also check cables with
this puppy. Call it a Z/100 box!
A post I made seven years ago yesterday, reposting an earlier post...
Subject: Re: ESR of large caps?
Date: 1997/08/15
Message-ID: <
[email protected]>#1/1
References: <
[email protected]>
[email protected]>
Organization: Rowland Institute for Science
Newsgroups: sci.electronics.design
Kendall Castor-Perry says...
Will Rose writes[snip]
input and across-cap signals on X and Y, scale them so they fit across
the screen properly, then do a Lissajous. Wind up the sensitivity to
'open out' the small error gap; for any particular scale you're using...
What's with all these 50 ohm or even 1k-ohm resistors, fellas? When
I want to measure 0.01 ohms, etc. I want AMPS! not mA or uA of test
current! For modestly interesting results I used a HIFI amplifier with
a 2.5-ohm resistor. Several amp drive is a piece of cake! But for
more useful capacitor data, I created the apparatus described below,
which can achieve 0.0001-ohm resolution:
Subject: Re: 0.01ohm impedance measurments ?
Date: 1997/06/22
Message-Id: <
[email protected]>
Newsgroups: sci.electronics.equipment
Adam Craig Seychell said...
How can I measure impedances below 10 milli ohms at frequencies
of about 500kHz or less?
I measure impedances to 0.01 milliohm by using a fast high-current
pulse. Although it takes a little construction and setting up - as do
all high-current measurements - it's actually quite easy to do. Note,
this technique may damage devices which can't carry a high current for
a short time, but such a device likely won't have milliohm impedances
anyway!
The concept is simply to force a 10 to 100 amp current step through
the device and measure the voltage drop as a function of time. For a
10A pulse with a known dI/dt (say 10A/us) the voltage step (lasting
1us) is mostly due to the device inductance, L = v/(di/dt), then a
lower voltage plateau reveals the series resistance, r = v/i, and
finally an increasing voltage measures series capacitance,
C = i/(dV/dt).
The high current is supplied from a few large computer electrolytics
(e.g. I used two 33,000uF 15V units in series - note that the C * esr
figure-of-merit simply scales with physical size - select _large_
capacitors!). First, a modest power supply charges the capacitors,
then the cap's are used to charge an inductor with the help of a few
high-current MOSFETs, turned on with a single-shot pulse generator.
The pulse generator must supply a negative-going OFF-state discharge
current so as to set a sub 1us current rise time (adjusted with Roff)
in an avalanche diode, which steers the current to the device under
test (D.U.T.).
3 to 50 10 to 35V
--- 100 --+--- uH ----+---- avalanche ----+
+ | | diode |
computer D +------ scope probe
capacitor --G D.U.T.
| | S +------ gnd clip
----------+---------+-+-------------------+---- SCOPE chassis gnd
200us etc -- Roff -- |
pulse gen -------------+
All the measurements are made with a scope probe with the groung clip,
acting as a 4-terminal sensor. For example, 0.1m-ohm resolution
implies a 10mV measurement capability (1/5 div with a 5mV/div range
and a 10:1 scope probe) and a 10A current.
This method easily measures the inductance and resistance of say,
shunt resistors and high-current inductors, as well as the ESR,
inductance and capacitance of big computer capacitors. Although these
are time-domain measurements, for most purposes, the results are
easily translated to the frequency domain.
For my purposes, larger 100 to 500A current pulses from the same setup
provided very useful data for avalanche breakdown investigations, but
that's another story.
---------------------------- end quote -----------------------------
inductance spike
_ /
flyback | |
voltage | | due to dV/dt = i/C
| | \ ______
| |___,,,....-----'''''
_____________ / v = iR due to ESR
Here's the relevant waveform for the first 10us, before the current
in the coil has fallen too much.
