I cobbled together a variable bench PS using ideas from Elecronoobs and Great Scott youtube channels and using an old 135W computer PS.
The build uses an old aluminum chassis I had laying around so allowed me to run everything chassis-ground and eliminate a lot of black ground wires, which was pretty necessary because the case was just big enough for the PS board, buck-boost board and a fan (had to accommodate a choke that was part of the original PS too).
Anyway, it all works as expected, the dummy-loads don't get hot, the voltages are stable, BUT when I turn it on, there's a noticeable arc (visible & audible) in the mains power switch... and when I power it down, it takes a full 4-5 seconds for the LEDs and Volt/Amp readout window to go out (caps bleed-off?).
So, right now I'm making/breaking the hot side of the 120vac to power it on, the original power supply didn't have a power switch, you just plugged it in and relied on the green-to-ground to power it up (I still do that as a secondary 'enable'), so I'm thinking that it was originally intended to be 'powered up' at the mains level all the time because it has a heck of an inrush when using a switch to power it from mains.
Does anyone have any ideas that would let me use this with a power switch without frying the contacts? How about bleeding off the filter caps? Right now, I leave the switch on and just plug and unplug the line cord.
The PS board was removed from an old Lenovo, it's an AcBel PS. I upgraded the fan to a 12vdc-40cfm unit, the only difference I can see in the installation is that I didn't include two 2200pf 250vac ceramic caps that were wired from both the hot and neutral sides of incoming power to ground since I used a new three-prong socket on the chassis.
That's all I've got, inrush arcing on power-up and slow bleed at power-down.
