Platforms
Content
You don't need the voltage regulators. You can just compare the voltage you let from a potential divider using a thermistor with that obtained from a trimpot.
In both cases you are comparing the ratio between a voltage and the supply rail. The comparison remains valid even if the supply rail changes.
An LM317 must have an input capacitor and an output capacitor, you have none. An LM317 should have a resistor between the output and its ADJ pin of 120 ohms but yours are much higher and variable.
The output of an LM293 comparator can drive to ground but is disconnected when it goes "high". It needs a pullup resistor from its output to the positive supply voltage to make its output go high.
Thanks Steve. The first 2 LM317s are being used to vary the voltage to the fans based on the thermistor resistance.
Aaaagh. If you're doing that, it may pay to place a 120Ω resistor in series with a 100uF capacitor in parallel with the thermistor. That will ensure that the fan starts at full speed. It may help if you find the fan doesn't start at all on a very cold day.
Why do you need diodes to make an OR gate? The comparators have open collectors so that they make an OR gate.
The capacitor in series with the resistor means that the 120Ω resistor only dominates until the capacitor charges.
