Battery type for calibration reference
Hi, all.
My question has to do with how to provide a voltage calibration
reference for users who may not have access to decent equipment or
parts, or may not be especially technically inclined. What I'd like to
be able to say is "Get a new (some type) battery and measure it, it
will be within X% of (specified) voltage." In the good old days we
used mercury cells for stable references; I don't think those are
available any more, and even if they are I expect they would be hard to
find. But also, I'm not really interested in stability, just the
ability to get a single reference point.
So, what is the relative ranking of battery voltage accuracies? My
guess is that lithium coin cells are pretty good. But how good is
that? How does that compare to NiMH or NiCd after a fresh charge, or
new alkaline cells? Since this is just for a single-point calibration,
it might be reasonable to tell the user to do something that would not
be acceptable in normal use, like put it in a plastic bag in icewater
for 15 minutes before the measurement if that would give best accuracy.
Thanks for any information or ideas!
Bob Masta
redbelly
Hi, all.
Bob Masta
A battery for a voltage reference? Even for a beginner, you're way
better off with a Zener or voltage regulator. Battery voltage changes
with the relative concentration of its chemicals, and I'd never trust
them, even when new, to be reproducible enough to use as a reference.
Zener's are available at Radio Shack, and once you buy one you don't
need to go out and buy a fresh one every time you need a reference.
Mark
E
ehsjr
Hi, all.
In that case, any new alkaline will be fine. They don't need
accuracy to even tens of millivolts. Doesn't negate your
question (below), tho. It would be interesting to know what *THE*
best battery for the purpose is.
Ed
What I'd like to
David L. Jones
Hi, all.
Bob Masta
Forget that.
What you want is a precision voltage reference IC.
Just feed in a wide ranging voltage (a 9V battery is fine for portable
applications), and you get out a precision fixed voltage that is as
stable with time and temperature as your wallet dictates. Even one for
a few dollars will have 0.1% or better and a low tempco, and you can
get a lot better than that. A common voltage is 2.5V.
Use precision 0.1% (or better) resistors as a voltage divider to get
other voltages.
Dave :)
Hi, all.
<snip>
Thanks for the "voltage regulator" responses, but as noted above this
is intended as advice to non-technical users. Put another way, what's
the best absolute voltage reference a non-technical person can buy in a
drugstore or maybe a (third-world?) country "general store". No
circuits that might intimidate. Batteries seem to be pretty widely
available and non-intimidating; I can't think of anything else as a
likely candidate. ("Stick a copper wire and a galvanized nail into a
lemon" probably isn't
gonna cut it!)
Best regards,
Bob Masta
David L. Jones
<snip>
gonna cut it!)
Best regards,
Bob Masta
Why would a non-technical person want a stable voltage reference?
BTW, voltage references aren't complex - one chip with 3 pins (supply,
gnd, ref out), that's it no "circuit" required. Shunt types might need
an additional resistor, but that it.
Local electronics stores carry basic types.
Dave :)
redbelly
gonna cut it!)
Best regards,
Bob Masta
I guess if you're ruling out Radio Shack as a place to shop, I can't
offhand think of a good alternative. My problems with recommending a
new battery are:
(1) After some use, the voltage will drop. How is a non-technical
person to know when it is time to buy a fresh reference?
(2) You have to change a layperson's thinking because a new alkaline
is NOT 1.5V, new "3V" Li ion batteries are not 3.0V, and new 9V
alkalines are not 9.0V.
But, it just might have to do.
What do you have planned for this? Some sort of online, basic
"hands-on" tutorial?
Mark
Rheilly Phoull
Hi, all.
to be able to say is "Get a new (some type) battery and measure it, it
to find. But also, I'm not really interested in stability, just the
calibration, it might be reasonable to tell the user to do something
that would not be acceptable in normal use, like put it in a plastic
bag in icewater for 15 minutes before the measurement if that would
give best accuracy.
Bob Masta
Yeah, like the others I cant see where "Non technical user and calibrating a
meter" will co-exist.
Not trying to knock but there are limits!
E
ehsjr
Dave :)
The op said stable was not the issue: "But also, I'm not
really interested in stability, just the ability to get a
single reference point."
How about this scenario (which happens on the newsgroups
from time to time): "I measured the voltage at point x
and it was 1.4 volts, but I don't know if my meter is
right." ?
Ed
Puckdropper
So if it's right at that point, what's to say it will be right at other
points?
right." ?
Ed
Get a second opinion. ;-) If you're not certain you can trust your
meter, it does you no good. It's time to replace it with something you
can trust.
Puckdropper
David L. Jones
You usually buy a voltage reference for its accuracy, the stability
comes with along with that for free.
i.e. it'll be 2.5V+/-0.1% with stability so good you don't have to
worry about it.
You simply can't beat a bandgap voltage reference for accuracy,
simplicity, and price. It is the right component for the job, period.
If you are talking about a short term "transfer standard", then a
battery (fresh or otherwise) is perfect, but you need a calibrated
meter to measure it on first.
right." ?
Ed
My answer is the same, go buy a bandgap voltage reference, they are
available almost everywhere (except maybe Radio Shack!) and cost a buck
or two. Anyone who shops only at Radio Shack simply does not need to
know if their meter is accurate to that degree.
Dave :)
Jonathan Kirwan
I can think of a few cases, neither of which probably apply to this
case though: 1) A child growing up in a very poor family, but
learning, and wanting to actually _do_ some science on the cheap or
just learn. 2) Someone living in circumstances where there is no
infrastructure but only primitive raw materials and physical theory to
go on. This case, of course, presumes a meter in hand and that
generally means that there either is infrastructure, money, or else
it's a one-off that just happened to fall into poor hands (given,
perhaps?)
If they exist. Sometimes it's just fun to answer the general question
from physical theory -- for example, what kinds of materials that can
be readily found and with low technology means turned into a
reasonable voltage reference that provides _any_ valid approximation.
Think of this in terms of what can be described on paper in words in
sufficient detail that they can be replicated reasonably well, say, 2
millennia ago. Would be interesting, no?
Some time ago, someone I knew currently living among native indians in
South America asked me about the possibility of arranging a way they
could make their own AM radios. Batteries were impossible to be had,
so of course the idea of a "crystal set" came to mind. I set about to
describe how to make an AM receiver. Galena was locally available,
luckily, so that was a good starting point. Needles of metal (steel)
were also locally available. Together, with a little bit of molten
lead, that was sufficient to make a diode detector. The result was
that I gave them instructions for fabricating circular permanent
magnets, coupled with flat bits of metal for diaphragms, wound wire,
etc, to make their own higher impedance earpiece (which was the harder
part of this), along with the rest (tuning coil, capacitor) to make an
AM radio from what could be accessed in what was then rather a remote
area.
[All kinds of wonderful things can be done with simple items. You can
fabricate a microbarometer capable of detecting an elevation change of
less than a meter using DOT brake fluid from a car, some glass tubing,
two LEDs, some nichrome wire from a toaster, and a few other bits.]
I think it's interesting to think about how to develop a voltage
reference from common materials available in different locals.
Sometimes, one might want to make one and doesn't have access to high
tech resources for the purpose.
What would you do if you were making such a voltage reference and
lived, say, 100 years ago and there were no ICs, transistors, bandgap
references, and so on? Yet you wanted to "do science" all the same?
What about 200 years ago?
I haven't done the experiments to see, but I wonder about using two
dissimilar metals, freshly sanded with emery paper and placed in a
lemon or lime for a short time (the reactions will soon block the EMF,
but fresh metal surfaces placed a consistent distance apart may
provide a reasonably repeatable result. Unfortunately perhaps not a
_known_ result from theory, though. So accuracy would still be in
question.
Still, copper sulfate pentahydrate (simple, hydrated copper sulfate)
is available as root killer at garden supply stores. Which is a
copper salt. That, with copper wire can easily provide one half of a
wet cell with known (predictable) voltage. The only need would then
be to find another metal and an associated salt for the solution. One
could then use either a saline bridge between (traditional method) or
else just use sausage casings (squish out the sausage first and wash
thoroughly!) filled with one of the salts and the metal electrode and
immerse it directly in the other salt solution.
Anyway, the electric potentials from the reactions are readily
available for calculation -- for example, the standard Cu/Zn combo
yields a predicted (+0.342 - -0.762) = 1.104V of potential difference.
I'm going to set about the local store today and see what I can easily
find to test this out. (1) copper sulfate (root killer), (2) sausages
for their casings to use as a porous membrane, (3) copper wire, (4)
angle iron, (5) ferrous or ferric sulfate (etchant or moss kill) to go
with the iron, (6) aluminum, sanded, from pop cans, (7) aluminum
sulfate from "slug kill" supplies. Might be fun. That's three metals
and their salts to play with and a porous membrane.
Jon
redbelly
Those potentials are for 25 C temperature, a 1 M concentration of
solutions, and 1 atm pressure of any gasses involved in the battery
chemistry. Deviate from those, and the voltage changes.
Mark
