Thanks Steve, and since Lithium "cells" are far more sensitive to overvoltage than NiMH or NiCd "cells", i suspect that individual cell voltage monitoring in a series stack is far more important in lihium batteries than in NiMH and NiCd batteries?
...but the problem with NiMH batteries is that its not possible to slow charge them at rates of 0.1-0.3C, as the following describes....
I am baffled at the sixth paragraph down of the following web page from batteryuniversity.com, which states that it is impossible to charge NiMH at slow charge rates...............
http://batteryuniversity.com/learn/article/charging_nickel_metal_hydride
It is difficult, if not impossible, to slow-charge a NiMH battery. At a C‑rate of 0.1 to 0.3C, the voltage and temperature profiles fail to exhibit defined characteristics to measure the full-charge state accurately and the charger must depend on a timer. Harmful overcharge will occur if a fixed timer controls the charge. This is especially apparent when charging partially or fully charged batteries.
.....surely this cannot be right?.......if charge is going in, even if only slowly, then surely the battery is charging up?
