Roger Dewhurst
I have an Arlec 12 volt battery charger which I accidentally blew up when
the 3 pin plug touched the chassis of my truck while the leads were clipped
to the battery. The circuit contains three resistors, what I think is a
small Zener diode, two large diodes and a peculiar elongated glass tube with
two wires leading in at one end. It has been glued in place between the two
diodes and connects to the input from the transformer. The glass tube is
about 30mm long and 5mm in diameter, It appears to be either gas filled or
evacuated. It reminds me slightly of a diode valve. Could it be some form
of capacitative device to smooth the waveform? Since the transformer
appears to be OK I suspect that it is either this tube device or the Zener
diode that has blown. Can anyone offer any suggestions? The Zener, if that
is what it is would be about 12.5 volts, would it not? The charger cost
less than $20 and a technician would charge twice that just to open the box!
