Are we buying stolen lamps?
Ali Coleman
I am in the UK.
The bargain of the moment seems to be the discount store long-life bulb.
I mean the compact fluorescent type (CFL).
China may have cheap labour but I would imagine that the materials cost
of a CFL would not be vastly different than elsewhere. The electronics
is not elaborate but it is not entirely trivial. The folder cylindrical
bulbs and their coating have a real cost.
So how is it that these bulbs are so cheap? To look at their packagaing
and steady supply of bulbs, it does not seem they have come from a quick
sale of surplus stock.
So have they been slipped out the back door. A missing lorry or two in
China and arrived here in their tens of thousands?
Or is the explanation much more rational and less dramatic?
Don Klipstein
I am in the UK.
Many dollar stores in the US (with the "Dollar Tree" chain appearing to
me to be a notable exception) have compact fluorescents. They usually
come in packages that say "energy saving bulb".
These are usually quadtubes but some are now spirals or
tripletwintubes. The quadtubes usually cost $1. The spirals and
tripletwintubes mostly in my experience cost $1.50 to $2.
These come in claimed wattages anywhere from 9 to 36 watts, and claimed
light output anywhere from that of a 40 watt incandescent to that of a 150
watt incandescent. A few have light output claims in lumens, anywhere
from 505 to 1800 lumens. In my experience, none significantly outshone 40
watt A19 "standard" lamps of "Big three" brands.
Actual power consumption of these is mostly under 13 watts, at least for
quadtubes of any nominal wattage.
Most have "daylight" bluish color ranging from 6600 to 8,000 Kelvin
(eyeball estimate), including many that claim "soft warm white light".
Most have halophosphate phosphor.
In my experience, perhaps about 7-8% were DOA or failed early or
significantly malfunctioned. Failures are sometimes not all that passive.
I had one produce smoke and an orange glow in its base after conking out 3
minutes into its operating life. A friend of mine reports one that
produced three "pop" sounds when failing, with two of the pops being loud.
And in my experience perhaps another 5% malfunctioned less significantly
(arc snakes after long periods of non-use or lamp needs to be touched to
start when cold).
And I have tested perhaps 60-65 units so far, 17 "brands", 43 "models",
with none seeing enough use to get a good idea of their life expectancy.
I doubt these are stolen. I see a few variations including the three
bulb styles and 5 distinct phosphor formulations so far among these
cheapies. And I see a lack of higher price ones like these anywhere -
especially in places other than dollar stores. I believe that these
junkers are in at least somewhat routine production.
- Don Klipstein ([email protected])
Z
Zak
Ali said:
I am in the UK.
Lower quality and lower marging. Lower marketing cost. And so on. A
Philips Genie is 6 euro as a brand product, but you see them for 3 as
well without the name (but clearly the same product).
The no-name lamps are, as Don wrote, of much lower quality. Electronics
can be saved on (not using tube-saving startup methods, no interference
suppression, lower reliability margins, missing fuse, and just cost
optimization because the price has to be so low). Phosphor can be saved on.
All in all it is still amazing what 70 cents can buy...
Thomas
Al Coleman
In sci.engr.lighting Zak said:
I don't.
I see them as low as 0.71 euro, in my local supermarket.
For 11/22W philips genie.
The packaging is spot on, and they are being sold from display
boxes of maybe 3000 on the supermarket floor.
I'd guess that the store (one of several hundred in the UK, a
smallish branch of Morrisons) is selling 6000/wk.
As to their reliability, I have a string of ~15 wired in series.
They have so far been on for maybe 60 hours, and 40 starts.
One has stopped working.
I haven't investigated if it's a mechanical failure of the holder,
or supply, or the bulb itself has failed.
Philips 6 years* Genie 230-240v~ 50-60Hz B22 BC 6000h
600 lumen 80mA 11 watt / 60 watt order code 797254xx
(and on the side light output measured according to iex 969
standards, compared to a 1000hr soft tone bulb of similar light
output. Lifetime based on an average of 3 hr/day burning)
Ian, I too am in the UK but I haven't tried the Morrison CFLs.
(0.71 Euros = 50 UK pence = 90 US cents. Is this right?)
I have tried the "pound shop" CFL bulbs and at approx one pound (= USD
1.80) they are great. The colour temperature is actually very nice and
not at all like the sickly green-yellow I have seen before and what's
more they seem distinctly brighter than the claimed equivalent-wattage
tungsten lamps.
I guess there may be a large percentage of failures as Don suspects or a
shorter total life although I don't have enough samples to know this and
I too have not had any outright failures.
So they seem to give a bright and comfortable light which is better than
the light from a tungsten GLS lamp. Of course, GLS lamps don't set a
very high standard but earlier CFLs were not even as good as a GLS.
Clive Mitchell
to me to be a notable exception) have compact fluorescents. They
usually come in packages that say "energy saving bulb".
Most of these lamps are easy to separate and the base makes a very
useful enclosure for small mains powered circuits to plug into a
lampholder.
Before LED mains lamps became so common I made a load for myself using
small circuit boards mounted into these cheap bases.
Ben Miller
start when cold).
The infant mortalities are often workmanship issues. I opened up one that
failed after about an hour, with an obvious smell of escaped smoke. The wire
leads from the lamp itself were pushed through the circuit board holes and
soldered, then the excess tag end was bent over against the adjacent lead,
causing a short circuit. I have seen this same problem in large fluorescent
fixtures. The workmanship in many of the imported electrical devices is
terrible.
Ben Miller
Andrew Gabriel
I don't.
The packaging is spot on, and they are being sold from display boxes of
I'd guess that the store (one of several hundred in the UK, a smallish
They are the same price in ASDA (UK name of Walmart).
Al Coleman
You've GOT to be kidding!
Do you go down every isle at the hardware store and marvel "how is
this so cheap"? It's a fact of modern life, mass production of
goods does this. Why significantly cheaper than a premium brand?
How did you think those large corporations got so large? Profit
margins. For all we know, these generics might sold by the
gazillions in China, or even by major brands tryign to compete in
the generic market without devaluing their retail branded
alternative as much while still making some profit at that
price-point.
Others implied lower quality. Perhaps, but there are two (at
least) important factors here:
1) Would-be engineers will often poo-poo anything not esthetically
perfect. In the end "does it work, long term and safe enough" is
what matters most.
2) Any cheap generic product is likely to not undergo the same
standards of QC, product testing. Early generations may have more
bugs so everyone sees some product with a bad failure rate and
remembers this, but ignores that it was a beta product essentially,
that a couple years later these issues were worked out, but those
who had the problem may never know as they have sworn to now buy
only the brand costing significantly more instead. Unfortunately
they will sometimes even vehemently argue for the brand they chose
later, citing lots of marketing fluff instead of ever getting to
the meat-n-potatoes, what the actual fault condition was in the
first generic and whether subsequent revisions corrected it.
So the answer in short isn't "why so cheap", it's "where have you
been to not notice modern economy?" In the end it's the same
story, different day, you make a small gamble buying product,
qualifying it for your needs or disqualifying it.
You are dead right that many things have got a lot cheaper. But the
value which a CFL bulb gives is oustanding. At the discount shop price
they undercut the mainstream product approximately by a factor of 4 or 5
or maybe more.
Despite the tales of poor assembly, the components seem to be of
reasonable quality. This is a far better bargain than those packs of
subminature screwdrivers which seem to be made from rubber which sell
for the same sort of price or even a large bottle of liquid detergent.
Some products in the, er, new economy are much better value than others.
Some people may not see this and have no idea of product complexity or
design and think that everything's cheaper so something extra-cheaper in
the same as something else which is slightly-cheaper.
Nope, the cheapo-cheapo CFL is a real lollapalooza.
Don Klipstein
or maybe more.
I have heard good things about the roughly $2 CFLs from Ikea, and I know
someone who has dozens of them in use, used for them for years, and swears
by them.
But these surely appear to me as being much different from the $1 to $2
ones at dollar stores. The latter I would not swear by at all - I would
rather swear *at* those and at whoever gets them there and the FTC for not
noticing any of those and how far short of claimed light output most of
their actual light outputs are.
Ali Coleman
I know someone who has dozens of them in use, used for them for
years, and swears by them.
to $2
would rather swear *at* those and at whoever gets them there and
the FTC for not noticing any of those and how far short of claimed
light output most of their actual light outputs are.
Don, ah yes but then you are seriously deep lighting fella.
As for shortfall in light o/p.
That used to be very true here in the UK but the cheapo-cheapo lamps
seem to me to be brighter (yes!) than their claimed equivalent.
It never used to be like that but that's my experience now with my
local discount stores.
Don Klipstein
rather swear *at* those and at whoever gets them there and the FTC for not ^^^^^^^^^^^^^^^
I did word that hastily - no, I was not thinking about cursing out
dollar store customers for buying the clunkers - probably largely
unsuspecting what these are like and how much worse they are than other
CFLs. I meant to say "brings them there" - as in the supply chain.
Bob Ferapples
Thomas
This is the best answer in my opinion, except for the one main
ommission. The reason why they can be made so much EXTRA cheaply in
China is because they have far fewer environmental restrictions on
handling phosphor and mercury than most other countries do. To them,
prison labor handling hazardous materials is a way to eliminate 2
problems: labor cost and excess undesireable population. The Nazi's
did similar things years ago, but we stopped them eventually. We don't
care about their doing that to their own people in China, they aren't
as "real" to the rest of the world.
