Ross Herbert
On Mon, 26 Jan 2009 20:22:41 -0800, Archimedes' Lever
:On Mon, 26 Jan 2009 18:49:35 -0800 (PST), MooseFET <[email protected]>
:wrote:
:>> On Sun, 25 Jan 2009 12:18:33 -0800 (PST), MooseFET <[email protected]>
wrote:
:>> :On Jan 25, 2:47 am, "Frithiof
:>> :> "Nemo" <[email protected]> skrev i
:>> meddelelsen:>> :>
:>> :> > Thank you everyone, loads and loads of useful info there.
:>> :> > To answer your concerns, I don't think ground loops aren't a problem,
but
:>> :> > I'll look into that. I usually secure ferrites to cables with some heat
:>> :> > shrink. I suspect the lowest frequency of interest is about 5kHz - I'll
:>> :> > need to check the system specs there, but certainly not DC.
:>> :> > Nemo
:>> :> For frequencies that low you may be better off with an "iron" core or
maybe
:>> :> a iron powder toroid.
:>> :Remember that the core is intended to remove things that are
:>> :unwanted. The frequencies of the unwanted currents is what really
:>> :matters.
:>> Yes, and the ferrite on the coax is intended to prevent the shield of the
cable
:>> radiating EMI/RFI from the equipment it is connected to where it can be
picked
:>> up by other sensitive equipment. The ferrite is not there to prevent the
:>> equipment it is connected to from picking up stray noise.
:>I have used them to prevent the equipment they are on from picking up
:>noise. If you have a large signal source nearby and a coax that is
:>some significant part of a wavelength long, you can end up with large
:>RF currents flowing in the shield and coupling into the core of the
:>coax.
: When you get up into GHz ranges, they are referred to as 'spurs'.
: One reason why there are not very many switchers used in these bands.
:Linear supplies make a friggin' rack module pretty heavy.
: We need a switcher that has a super-smooth output that has no HF
:switcher noise included with it. So what? Super caps, computer grade
:cap banks?
: How do we reduce switcher noise so that they do not pose a problem with
:GHz range RF bands?
In my experience the average switchers pump out wideband noise consisting of
many harmonics and they only vary in the degree and level of noise produced. As
such, it is very difficult to suppress pickup on low level input lines in
sensitive equipment. Filtering individual input lines will usually help but the
best solution is to stop it from being produced in the first place, but that
requires special attention in the design of the switcher. It is for this reason
that military and medical grade switchers cost more than the run-of-the-mill
switchers.
but
:>> :> > Nemo
maybe
:>> :matters.
cable
picked
:>coax.
:cap banks?
switchers.
