Arduino String or string
Can someone explain how to make a string in Arduino?
Also whats the difference between String, string, char *, and char T[]?
I would ask on Arduino.cc forums but for some reason it says im blocked when I tried posting over there.
If you want some code....to look at let me know! I am omitting it right now because I do not think this site is that oriented towards programming.
Good evening Nickr676
This is ideally where you should start before heading off into Arduino which i think would be of great benefit to you
Here is the site address
https://www.programiz.com/c-programming/c-pointers-arrays
Read the entire chapter and by the end of this , after practising the examples , which you can do in C locally and without having to blow an Arduino with code this will then all make perfect sense
Hope that helps you
