Depends on the reed switch and the motor being used. The motor will draw a certain current and the reed switch contacts must be able to carry that current. Typically, reed switches can carry around 1A maximum therefore your motor should be rated UNDER 1A. You can, of course, increase this maximum current by using the reed switch to activate a relay and the relay contact to activate the motor - in which case there is no practical limitation on the current.
