This is where mathematics comes into it.
Modulation involves multiplying two sine waves.
Sin(A) * sin(B) = sin(A+B) + sin(A-B)
In othe words sidebands will be produced above and below the carrier.For normal AM, the carrier is transmitted along with the sidebands. The original low audio frequency will not get through the transmitter which will be tuned around the carrier frequency.
Modern ham transmitters use single sideband where the audio frequency is balanced out and the carrier also, one sideband only is then selected. This gives a low bandwidth and the transmitter only gives an output when there is information to be transmitted, alowing higher peak powers.
If you do a Fourier analysis of the signal in #25 you will see that you have a carier with two sidebands.
