Ron Baker, Pluralitas!
isw said:Hint: Modulation is a "rate effect".
Isaac
Please elaborate. I am so eager to hear the
explanation.
Isaac
isw said:Two tones 100 Hz apart may or may not be perceived separately; depends
on a lot of other factors. MP3 encoding, for example, depends on the
ear's (very predictable) inability to discern tones "nearby" to other,
louder ones.
Yup. And the spectrum analyzer is (hopefully) a very linear system,
producing no intermodulation of its own.
Isaac
Don Bowey said:On 7/4/07 10:16 AM, in article [email protected],
On 7/4/07 7:52 AM, in article
[email protected],
"Ron
<snip>
cos(a) * cos(b) = 0.5 * (cos[a+b] + cos[a-b])
Basically: multiplying two sine waves is
the same as adding the (half amplitude)
sum and difference frequencies.
No, they aren't the same at all, they only appear to be the same
before
they are examined. The two sidebands will not have the correct phase
relationship.
What do you mean? What is the "correct"
relationship?
One could, temporarily, mistake the added combination for a full
carrier
with independent sidebands, however.
(For sines it is
sin(a) * sin(b) = 0.5 * (cos[a-b]-cos[a+b])
= 0.5 * (sin[a-b+90degrees] - sin[a+b+90degrees])
= 0.5 * (sin[a-b+90degrees] + sin[a+b-90degrees])
rb
When AM is correctly accomplished (a single voiceband signal is
modulated
The questions I posed were not about AM. The
subject could have been viewed as DSB but that
wasn't the specific intent either.
What was the subject of your question?
Copying from my original post:
Suppose you have a 1 MHz sine wave whose amplitude
is multiplied by a 0.1 MHz sine wave.
What would it look like on an oscilloscope?
What would it look like on a spectrum analyzer?
Then suppose you have a 1.1 MHz sine wave added
to a 0.9 MHz sine wave.
What would that look like on an oscilloscope?
What would that look like on a spectrum analyzer?
John Fields said:Now you get to explain why the beat is measurable with instrumentation,
and can can be viewed in the waveform of a high-quality recording.
Simple. The process isn't totally linear, starting with the musical
instrument itself, so some heterodyning will inevitably occur which
will be detected by the measuring instrumentation.
Don Bowey said:On 7/4/07 8:42 PM, in article [email protected],
"Ron
[email protected],
"Ron
<snip>
before
relationship.
relationship?
carrier
(For sines it is
rb
modulated
What was the subject of your question?Copying from my original post:Suppose you have a 1 MHz sine wave whose amplitude
What would it look like on a spectrum analyzer?Then suppose you have a 1.1 MHz sine wave added
The first example is amplitude modulation precisely _because_ of the
multiplication, while the second is merely the algebraic summation
of the instantaneous amplitudes of two waveforms.
The circuit lists I posted earlier will, when run using LTSPICE,
show exactly what the signals will look like using an oscilloscope
and, using the "FFT" option on the "VIEW" menu, give you a pretty
good approximation of what they'll look like using a spectrum
analyzer.
If you don't have LTSPICE it's available free at:
http://www.linear.com/designtools/software/
Ron said:...
John Fields said:On Thu, 5 Jul 2007 00:00:45 -0700, "Ron Baker, Pluralitas!"
analyzer.
[email protected],
"Ron
<snip>
before
relationship.
relationship?
carrier
(For sines it is
rb
modulated
Ron said:I'll remember that the next time I'm tuning
an MP3 guitar.
What does a spectrum analyzer use to arive at
amplitude values? An envelope detector?
Is that linear?
Ron Baker said:Please elaborate. I am so eager to hear the
explanation.
Ron Baker said:I'll remember that the next time I'm tuning
an MP3 guitar.
Is that linear?
and why don't you try being a little less of a pompous ass?
Ron Baker said:Is there multiplication in DSB? (double sideband)
John said:But it is true.
The human ear has a logarithmic amplitude response and the beat note
(the difference frequency) is generated there.
The ear does happen to have a logarithmic amplitude response as a
function of frequency, but that has nothing to do with this
phenomenon. (It relates only to the aural sensitivity of the ear at
different frequencies.) What the ear responds to is the sound pressure
wave that results from the superposition of the two waves. The effect
in air is measurable with a microphone as well as by ear. The same
thing can be seen purely electrically in the time domain on an
oscilloscope, and does appear exactly as Ron Baker described in the
frequency domain on a spectrum analyzer.
The sum frequency is
too, but when unison is achieved it'll be at precisely twice the
frequency of either fundamental and won't be noticed.
The ear does not hear the sum of two waves as the sum of the
frequencies, but rather as the sum of their instantaneous amplitudes.
When the pitches are identical, the instantaneous amplitude varies
with time at the fundamental frequency. When they are identical and
in-phase, the instantaneous amplitude varies at the fundamental
frequency with twice the peak amplitude.
When the two pitches are different, the sum of the instantaneous
amplitudes at a fixed point varies with time at a frequency equal to
the difference between pitches. This does have an envelope-like
effect, but it is a different effect than the case of amplitude
modulation. In this case we actually have two pitches, each with
constant amplitude, whereas with AM we have only one pitch, but with
time varying amplitude.
The terms in the trig identity are open to a bit of misinterpretation.
At first glance it does look as though we have a wave sin(a+b) which
is being modulated by a wave sin(a-b). But what we have is a more
complex waveform than a pure sine wave with a modulated amplitude.
There exists no sine wave with a frequency of a+b in the frequency
spectrum of beat modulated sine waves a and b. As has been noted
previously, this is the sum of two waves not the product. I think it
can also help not to inadvertantly switch back and forth from time
domain to frequency domain when thinking about these things.
ac6xg
That would suggest that there could be "low IM" instruments which would
be very difficult to tune, since they would produce undetectably small
beats;
in fact that does not happen. It would also suggest that it would
be difficult or impossible to create beats between two
very-low-distortion signal generators, which is also not the case.
Other than the nonlinearity of the air (which is very small for
"ordinary" SPL, there's no mechanism to cause IM between two different
instruments, although beats are still generated. The beat is simply a
vector summation of two nearly identical signals; no modulation needs to
take place.
Or consider this: At true "zero beat" with the signals exactly 180
degrees out, no energy is avaliable for any non-linear process to act on.
Well, no, mostly they don't, until you get to really high SPL.
phenomenon.
Regardless of the frequency response characteristics of the ear, its
response to amplitude changes _is_ logarithmic.
For instance:
CHANGE APPARENT CHANGE
IN SPL IN LOUDNESS
3 dB Just noticeable
5 dB Clearly noticeable
10 dB Twice or half as loud
20 dB 4 times or 1/4 as loud
You missed my point, which was that in a mixer (which the ear is,
since its amplitude response is nonlinear) as the two carriers
approach each other the difference frequency will go to zero and the
sum frequency will go to the second harmonic of either carrier,
making it largely appear to vanish into the fundamental.
But the resultant waveform will be distorted and contain additional
spectral components if that summation isn't done linearly. This is
precisely what happens in the ear when equal changes in SPL don't
result in equal outputs to the 8th cranial nerve.
That's not true. In AM we have two pitches, but one is used to
control the amplitude of the other, which generates the sidebands.
No, it's much simpler since you haven't created the sum and
difference frequencies and placed them in the spectrum.
"Beat modulated" ??? LOL, if you're talking about the linear
summation of a couple of sine waves, then there is _no_ modulation
of any type taking place and the instantaneous voltage (or whatever)
out of the system will be the simple algebraic sum of the inputs
times whatever _linear_ gain there is in the system at that instant.
Real modulation requires multiplication, which can be done by mixing
two signals in a nonlinear device and will result in the output of
the original signals and their sum and difference frequencies.
After you get done talking about modulation and sidebands, somebody
might want to take a stab at explaining why, if you tune a receiver to
the second harmonic (or any other harmonic) of a modulated carrier (AM
or FM; makes no difference), the audio comes out sounding exactly as it
does if you tune to the fundamental? That is, while the second harmonic
of the carrier is twice the frequency of the fundamental, the sidebands
of the second harmonic are *not* located at twice the frequencies of the
sidebands of the fundamental, but rather precisely as far from the
second harmonic of the carrier as they are from the fundamental.
John said:You missed my point, which was that in a mixer (which the ear is,
