Alarm circuit with and gates?
K
kash
I remember quite a log time ago someone built an intermittent alarm sound
circuit with an IC of 4 and gates (perhaps it was or or xor, not 100% sure)
Does anyone know what I'm talking about ? It may be that the 555 was
also used, not sure, can we create an oscillation with just a couple of and
gates?
John Fields
gates?
Yeah, sure.
Or maybe that was three and gates. Shouldn't an odd number give you the
inversion you need?
Or maybe that should be two nands, an xor and an and or an or or a nor?
Or not? I don't remember, it's sooooo confusing.
K
kash
John Fields said:
Yeah, sure.
inversion you need?
Come to think of it, yes I do think it was nand actually. They must have been
all of the same type since this is how they come as IC's.
I wish I had the circuit, perhaps you could post a circuit?
K
kash
Ken Taylor said:
Search engines reveal all.
http://www.robotroom.com/InfraredTransmitter.html
for *one* example circuit.
1. Yes, it's good, why do we use the extra two top gates, is it for isolation
from the oscillation part, if so, why use both top nands, one should be
enough?
2. Now how can we get an on-off oscillation? maybee we can use the
top nands as an oscillator of about 1hz to control the Enable of the
bottom oscillator, but then we won't have en extra gate as a buffer
K
Ken Taylor
enough?
Using digital stuff in this way is evil, but that's just a philospohical
point. :) The two top NAND's are cleaning up the waveform and buffering. To
switch it on and off at, say, 1Hz, replace the 'make' switch with another
similar circuit set for 1Hz.
Cheers.
Ken
Steven Murray
Chances are it was the CD4093.
A schmitt trigger quad dual input NAND.
It has a wide supply range, also.
In terms of functionality within one part, you can do an awful
lot with this single, cheap, chip. One NAND alone can be a gated
oscillator, for instance, or you can cross couple two of them to
get an RS flip flop while still retaining schmitt trigger inputs.
No, I can't post circuits - as Ken Taylor said - use search engines.
N. Thornton
Instead of using a 4x NAND, use a hex schmitt invertor. Lots more
games you can play per chip that way.
Regards, NT
John Fields
Thanks for the circuit (a circuit is better than a 1000 words)
Thanks, but there's a mistake in the timing diagram. With '132's in the
circuit shown, the timing will look like this:
______________________ ___________
Y1_____| |________________________|
______ _ _ _ _ _ _________________________ _ _
Y2 |_| |_| |_| |_| |_| |_| |_| |_| |_
For the timing to look like this:
Y1____| |________________________|
_ _ _ _ _ _ _ _ _
Y2____| |_| |_| |_| |_| |_| |_________________________| |_| |_| |_
The gates in the circuit need to be HC 7002's (Schmitt trigger NORs)
John Fields
Well, to produce a little alarm it really doesn't matter if it starts up
or down does it?
That's not the point. What matters is what happens when it comes to
rest. Using NANds, the output of the circuit will be high when it's
inactive, meaning that if you're low-side driving a DC coupled load
connected to the+ rail it will always be on when the circuit isn't
oscillating. By using Nors the output always goes low when the circuit
is idle.
K
kash
What is a low-side DC coupled load ?
John Fields
I have no idea, but what I was talking about looks like this, where the
load is driven by connecting and disconnecting it from the low side
(GND) of the supply. In this case, the transistor is called a low-side
switch.
Assuming that you want a gated oscillator which oscillates when an input
line is in one state and doesn't oscillate when the input line is in the
opposite state, looking over this circuit a little more closely yields
that is has problems for your application whether NANDs or NORs are
used.
+V
[LOAD]
ON/OFF>-------A |
NAND Y1--+-------A C
+----B | NAND Y2--+--[R]---B
| | +----B | E
+---[R]----+ | | |
| +---[R]----+ GND
[C] |
| [C]
GND |
GND
Looking at a truth table for the circuit yields, for NANDs:
ON/OFF Y1 Y2
0 1 OSC
1 OSC OSC
And for NORs,
ON/OFF Y1 Y2
0 OSC OSC
1 0 OSC
So no matter what, the output will either be oscillating continuously or
oscillating periodically!
The following will work, albeit with a price increase of an extra chip!
I'm sure there are other thriftier configurations which will work, so
why don't you get out a pecil and some paper and see whether you can
figure something out?
+V
[LOAD]
ON/OFF>-------A |
+----B | NOR Y2--+--[R]---B
| | +----B | E
+---[R]----+ | | |
| +---[R]----+ GND
[C] |
| [C]
GND |
GND
ON/OFF Y1 Y2
0 1 O
1 OSC OSC
Jim Thompson
switch.
used.
+V
[LOAD]
ON/OFF>-------A |
| | +----B | E
+---[R]----+ | | |
| +---[R]----+ GND
[C] |
| [C]
GND |
GND
ON/OFF Y1 Y2
0 1 OSC
1 OSC OSC
And for NORs,
ON/OFF Y1 Y2
0 OSC OSC
1 0 OSC
+V
[LOAD]
ON/OFF>-------A |
| | +----B | E
+---[R]----+ | | |
| +---[R]----+ GND
[C] |
| [C]
GND |
GND
ON/OFF Y1 Y2
0 1 O
1 OSC OSC
See "CMOS-Osc-NoClip.pdf" on the S.E.D/Schematics page of my website.
Changing one inverter to a gate will allow stopping and starting.
...Jim Thompson
roma
sound circuit with an IC of 4 and gates (perhaps it was or or xor, not
100% sure) Does anyone know what I'm talking about ? It may be that
the 555 was also used, not sure, can we create an oscillation with
just a couple of and gates?
see page 18 http://members.shaw.ca/roma
roma
K
kash
No no, this is absolutely fine, I don't need an on/off switck, just
need an intermittant alarm.
switch.
used.
+V
[LOAD]
ON/OFF>-------A |
| | +----B | E
+---[R]----+ | | |
| +---[R]----+ GND
[C] |
| [C]
GND |
GND
ON/OFF Y1 Y2
0 1 OSC
1 OSC OSC
And for NORs,
ON/OFF Y1 Y2
0 OSC OSC
1 0 OSC
+V
[LOAD]
ON/OFF>-------A |
| | +----B | E
+---[R]----+ | | |
| +---[R]----+ GND
[C] |
| [C]
GND |
GND
ON/OFF Y1 Y2
0 1 O
1 OSC OSC
John Fields
"Gated" oscillator, Jim.
A high (or low) in will allow the thing to run and output a particular
frequency for a while and then nothing for a while and then...
OTOH, a low (or a high) input will shut it down.
Exchanging a gate for an inverter in your circuit will allow stopping
and starting, but it won't allow stopping and starting on a periodic
basis unless there's another oscillator in there toggling the start/stop
line and an input to control the gating oscillator and the "off" state
of the output.
