A friend just gave me a couple of "expansion batteries"
for my tablet PC's. Of course, the batteries are flat.
*And*, of course, they won't take a charge. :<
Pulling one open, there are 4 (5?) batteries that
appear to be identical distributed around the case
(the battery pack is very thin but as tall and wide
as the tablet).
Is it worth trying to replace these with some comparable
cells? (I am sure the vendor of the original expansion
pack would charge a heavy premium to put those cells in
this large plastic shell and resell it! :> )
What other issues might I have to worry about?
Or, is it better to just live with the standard (working)
batteries and discard the expansion batteries?
Thx,
--don
This is a complex issue.
Words like "flat" and "won't take a charge" may be clear in
your mind, but don't communicate much.
I've spent considerable time working on this issue.
The executive summary is, "give it up and go do something fun."
If you're gonna mess with this, there are some ground rules.
WEAR EYE PROTECTION.
DO NOT SKIP THIS STEP. I'VE HAD NiCd BATTERIES EXPLODE AND
SPRAY HOT CAUSTIC STUFF IN MY FACE.
Don't let your kids watch.
Don't leave it unattended.
Have an EMPTY metal trash can handy and a clear path to outdoors.
Make sure your fire insurance is paid.
Have a working fire extinguisher handy. It won't do much for
a lithium fire, but might keep the whole house from going up.
NEVER, NEVER, NOT EVER SHOULD YOU SOLDER DIRECTLY TO A BATTERY.
Repeat that until you believe it. Don't let anybody tell you otherwise.
Let them blow up their laptop if they want.
My experience is mostly with packs over 5 years old. Protection
circuitry becomes progressively more sophisticated.
I've experienced two failure modes.
1)cell is open. The pressure switch has opened and they ain't coming back.
2)High internal resistance. The amp-hours are in there, but the protection
circuit or the laptop won't let you take it out.
Of course it's possible that your cells are good and have just
overdischarged
and the electronics have disconnected 'em.
You've got it open, check the voltage of each cell. If it's over
2.5V, you can probably charge each one individually to some higher
voltage. 3.8V seems like a safe number. You want them all MATCHED
at the same voltage. That's my definition of "take a charge".
If the voltage is lower, there's higher risk that charging them will
start a fire.
I've recharged cells at low current from less than one volt, but I never
left it unattended.
Whether you've managed to recharge existing cells or replaced them,
you face the electronics problem.
The battery chip may have lost power. Its response varies.
I never got any thinkpad chip to let me restart the battery.
I managed to restart one NiCd battery that had a PIC processor
by resetting the PIC.
Dell C-series batteries come back, but when you press the test button,
you get a flashing light pattern. The laptop battery light flashes
continuously...but they seem to work ok.
Another wrinkle is that the battery remembers its current capacity.
If you replace the cells, it's likely that the memory contains the old
number and may not let you have more than that capacity. There are ways
to reset that, but it's a secret closely guarded by the battery rebuild
people.
If I'd spent all the time I spent working on this issue working at the
corner
burger joint at minimum wage, I could have easily purchased new batteries
for every laptop I've ever owned and still be money ahead.
Are we having fun yet?
