Aerial (roof) rotating antenna operation?
The particular case here is one of those systems where you have a light antenna on the roof, a little box inside controlled by a remote control for rotating clockwise or counterclochwise and the antenna connection and box is through a single coaxial cable.
My questions are:
1) is the box sending a decodifiable signal through the coaxial cable or,
2) is it a wireless communication that exists between the box and the antenna motor?
In the case it's through the coaxial cable, if the controller box (the one at the living room) is damaged but the motor is working ok, how can I control the motor (forward/reverse) even if I've to use another pair of cables for the purpose?
Thanks in advanced for any help on this!
The coax cable probably uses DC in it to drive the motor and it changes polarity to reverse the motor. The cable has a coupling capacitor to pass the signal and inductors in series with the motor so that the motor does not short the signals.
Thanks for replying, Audioguru!
That's a good explanation, it's a shame that I don't see any labels or engravements to give more details. Nonetheless, I think, since it's all taken apart, that my best chance is to put another dc motor (if I can find a suitable one) & bring four cables to operate both thing: zignal transfer & motor control.
Do you agree with this approache?
The existing motor should be fine, it needs only two wires for forward and reverse. The signal needs a coax cable. The antenna might need a balun to match it to the coax.
About 50 years ago I had the largest TV antenna in my neighbourhood with a rotor. On one channel I could pick up a distant station in one direction and another distant station in another direction. Apartment buildings caused ghosts on many local channels but I could rotate the antenna to pick a reflected signal that was the best. I received some FM stations that were so far away that I needed a map to find where it was. Then cable TV replaced it and I can see channels all over the continent in their different time zones.
De-scrambling pay-per-view was fun and easy.
The problem is that there's no motor... Have no idea as to how fast was it rotating much less the power output (torque) provided by it nor the mechanism that joined the motor with the antenna.
davenn
so where is the motor ... has some one else removed it ?
Might pay to look if a masthead amp is currently being used or required as most of these operate on DC these days. Although ac powered units are still available.
  1. I found a couple of dish-rotators from microwave ovens that work & found that they've pretty good torque for the task. It doesn't need to be directly coupled to the small mast so the strain to the plastic pinnions inside can greatly be reduced.
The only inconvenience is they're AC powered (115 VAC). I'll keep looking for other options!
Thanks for replying to all of you!
