Hi there I wonder if anyone can help me, I've got a Panasonic SA-PT570 surround sound home theatre system, the problem is it won't turn on, for the past couple of weeks it has sometimes taken a couple of presses of the on button on the remote control to make the machine come on, or I've had to hold the button for a couple of seconds to make it work, new batteries made no difference, ( we generally only use the remote control and not the buttons on the machine itself). But now it won't come on at all! Other than this issue with turning the machine on everything else worked normally once machine was on. when I attempt to turn it on now it makes the usual click noise but then there's a 2nd slightly quieter click about half a second later and the machine doesn't come on, however if I repeat the process of pressing the on button then after the 2nd go it doesn't make any click noise at all, just nothing, as if it were dead lol, if I unplug and plug back in it will make the click noises again when attempting to switch on but will only do this the first two times and then nothing if you keep trying, just dead, the same happens regardless of if I use the remote or the on button on the machine itself. I would please like to know if anyone knows what this fault might be? Is it fixable? Although I wouldn't have the skills to fix it myself I would like as much info as poss so I don't get ripped off if I take it to a shop to try and fix, I know this machine is rather old now and I'm new here but I can't afford to replace it so would really appreciate any help or advice, I think I've given as much info as I can/know, but please ask if there's anything u need to know that would help diagnose the problem. thank you for taking the time to read this.
Chris
Chris
