All my EE classes from ME degree are two decades and a different career away, looking for advice on simplest solution.
Working on an audio amplifier project using an integrated class D board designed for passive cooling. The board has a nice complement of self monitoring and protection functions. One is thermal shutdown when max temp passes preset point. Another is output of current temp as a falling voltage with rising temp, from about 4V down to about 2V.
I'd like to add a fan, but don't need it to run constantly. I'd like for it to be a safety so that there is a chance to keep things cool enough before the amp shuts itself down. Probably with a bit of hysteresis so that it continues cooling until well below the point where the fan was enabled. I think the voltage at corresponding self shutdown temp is around 2.6V. So maybe fan on at below ~3V and off when above ~3.2 to 3.5V.
I have a 5V supply internal to the amp that powers the fan (its a 5V PC fan chosen because I had 5V, not 12V readily available), and can also be used for whatever control circuit or logic is needed.
What do you guys and girls suggest as a straightforward way of accomplishing this? I thought about a couple of zener diodes and latching relays, but realized my EE skills are too rusty to sort out without a lot of pain. Would this be easier to accomplish with an arduino? Never messed with one, but not afraid to learn if you think that is easier. Having a little flexibility in adjusting the set points would be nice. Probably easy with microcontroller, but was hoping this was an obvious simple circuit you could point me to.
