that describes a power supply issue.
Platforms
Content
Well I pulled the power supply board. I checked and replaced the remaining electrolodic caps on board removed the big power caps tested and they passed tested fine. Checked over everything and resoldered where needed. Clean up the ground connect on the board has a rust on it may have been the culprit of this humm I spoke of. Used dim bulb tested everything checked good. So removed that from equation. Next I tested the bios of both side 41mv left 38 right. Then checked dc offset left 13.9 right 10.7 so it all checked out. Now plugged a speaker in to each channels no hum all quiet. Played cd turned it up some played fine! No sound or noises during the playing season 2 hrs. Also readjusted the bios first then offset and sound good. Only thing is power switch on power on I get a small pop not bad. And also at about 1030 of the dial of pre amp I am getting the distortion lights. I never checked the protection board might have to here. When it was working before I never got those light. Now it does seem to be playing a little louder than I think it did before. Maybe just me but I still think something is going on somewhere. Now I just check the amps ground floor no music just turned the volume up. And right side there’s is a air noise coming out of tweeter and a low almost not noticeable hum in the woofer. The left side has a hum in the tweeter and the woofer a little louder than the right side. Neither are noticeable unless you put your ear up to speaker. If you have any input on where to look now I would appreciate it. I am going to check the protection board here tomarrow night so will see if anything’s a missthat describes a power supply issue.
I have a question for you I need to find the component that controls the signal in the amp. It is getting too loud to fast does not match my other amps. So I ether put a pot on each channel or I find the culprit and fix it. Maybe a resistor? Any help will help in the end to get me a better night sleep. Had a dream I was using it and it blew up like a Granade lol. Anyway let me know if possible. Now there are two caps on the board that I put I. That are close but not the same as the old ones. Made a mistake going off scamatics . The caps are c609 &c610 was a 4.7 25v I replaced with 4.7 50v. The other one is c617 c618 original was 100uf 25v I replaced with 100uf 16v. Would either of those be doing it?Signal in and signal out ... that's excellent.
If the thing can track well enough to reproduce a signal, the active components are good. There could still be a sketchy cap in there, but nothing to warrant gutting it. I think it'll be a function of tuning now
Ok I am going to replace that one cap with a higher voltage cap. I moved the amp over to my system and plugged it into my yamaha c4 pre amp and it works fine. Volume matches the other speakers good! I had it on a Yamaha Rx 690 a/v receiver and was using the front pre outs on it. They must be set higher or something. I kinda had a gut feeling on that and sure enuf that was the problem. So amp is stable.the 4.7μ 25V should be alright ... the 100μ 16V ... umm no ... replace with same or higher voltage rating (within reason)
Yeah I will not sure why the scamatics for the amp have it as a 16v cap. I will be replacing it with a 25v cap elna smeloutstanding .... change out that sub value cap ASAP and it should give good service for the duration
i am not sure why they put that the part was 16v cap in scamaticsparts list. I am going to put a 25v there elna silmic ll cap in there. I wanted to ask I am not sure if you know a lot about audio electronics meaning parts to use to get better sound cap wise. I picked the silmic elna caps seem to sound good. Wonder if you know of any that are better or if I made a good choice on the caps?outstanding .... change out that sub value cap ASAP and it should give good service for the duration
Its a well known debate in audiophile circles as to what cap, transistor, tube, cable ect ect sounds best.Yeah I will not sure why the scamatics for the amp have it as a 16v cap. I will be replacing it with a 25v cap elna smel
