D from BC
That wording makes no sense.
Shrink tubing around wire adds insulation; OK so far.
"Wrap the tubing around..." is obviously the same as wrapping the
wire around - since the wire is inside the tubing...
Now the corker of non-sequiter: "heat-shrink to positively retain..."
would only result in squeezing the wire.
El stupidio.
I was taught all these written english rules and then I see'm all
broken in patents.
Often I'm analyzing the fkn language more than I'm analyzing the fkn
invention.
It seems like in patent writing it's important to nail down the claim
even at the expense of easy comprehension.
I think patents are only meant to be read by lawyers to fuss over
details.
It reminds me of the description for the turboencabulator..
Work has been proceeding in order to bring perfection to the crudely
conceived idea of a machine that would not only supply inverse
reactive current for use in unilateral phase detractors, but would
also be capable of automatically synchronizing cardinal grammeters.
Such a machine is the 'Turbo-Encabulator'. "The original machine had a
base-plate of prefabulated amulite, surmounted by a malleable
logarithmic casing in such a way that the two spurving bearings were
in a direct line with the pentametric fan. ... The main winding was of
the normal lotus-o-delta type placed in panendermic semi-boloid slots
in the stator, every seventh conductor being connected by a
nonreversible trem'e pipe to the differential girdlespring on the 'up'
end of the grammeters. "Forty-one manestically spaced grouting brushes
were arranged to feed into the rotor slipstream a mixture of high
S-value phenylhydrobenzamine and 5% reminative tetryliodohexamine.
Both of these liquids have specific pericosities given by P =
2.5C.n^6-7 where n is the diathetical evolute of retrograde
temperature phase disposition and C is Cholmondeley's annular grillage
coefficient. Initially, n was measured with the aid of a metapolar
refractive pilfrometer . . . but up to the present date nothing has
been found to equal the transcendental hopper dadoscope. ...
"Undoubtedly, the turbo-encabulator has now reached a very high level
of technical development. It has been successfully used for operating
nofer trunnions. In addition, whenever a barescent skor motion is
required, it may be employed in conjunction with a drawn reciprocating
dingle arm to reduce sinusoidal depleneration."
*clipped from http://en.wikipedia.org/wiki/Turboencabulator
Before my time...
D from BC
