Rich Grise
Ok, well now that we've determined that I fell victim to a bit of an
urban legend, I'm still curious why a 9 volt battery is so tiny, yet a
12 volt battery is the size of a concrete block.
The size doesn't have anything to do with the voltage. The voltage of a
given cell depends on the chemistry, and nothing else. For 9V, they
stack up little tiny 1.2V or 1.5V cells, that don't have much capacity
(as in amp-hours). Lead-acid cells are nominally 2V, so a stack of 6 of
them makes a "12V" "car" battery. The capacity is determined by the size
of the plates and amount of electrolyte that's available for the chemical
reaction, so the capacity is more-or-less proportional to the volume.
Also, something I read indicated a car battery has a sufficient CURRENT
to really hurt you, but too low a voltage. But I fail to see how that's
a true statement given Ohm's Law.
If you cut open your hands, and stuck electrodes into the open sores,
probably even a 9V battery could kill you - it only takes 15 mA through
your heart to cause fibrillation. The thing that protects you is your
skin.
Hope This Helps!
Rich
