If you use the negative side of the battery as a reference or zero volts then the emitter of the 2n3906 will be sitting at 1.5 volts. The base of that transistor is connected to the base of the other transistor. Assuming that both transistors are similar except for the polarity the pn junction of the 2N3906 and the np junction of the 2N3904 are effectively connected in series with the battery and therefor should be dropping or have the same voltage across both of them. Or looking at this another way the voltage on the NPN transistor emitter is zero volts, that is it is connected to the reference, the negative side of the battery. The base or np junction is connected to the base of the other transistor has 0.75 volts on it relative to your reference. The base of the PNP transistor therefore has 0.75 volts on it relative to your reference and the emitter has 1.5 volts because of the battery. The normal voltage of a np junction just as it starts to turn on is around 0.75 volts and the normal voltage of a pn junction is about -0.75 volts, the same but opposite polarity. You must keep in mind that in a normal pn junction you must apply about 0.75 volts on the p-channel of a silicone device to get it to turn. A NPN and PNP transistor work the same except the polarities are the opposite.
I know this is a long answer but the concepts are important.
So let's see what happens.
