Travis Evans
Quick question: Do general-purpose-lighting HID ballasts typically have
a built-in thermal protection device of some sort like some fluorescent
fixtures have?
I was operating a 70-watt metal halide ballast (traditional
iron/magnetic type; not electronic) with the proper lamp, but in an
enclosure where it may have built up too much heat and run hot (the
metal box in the luminaire was intended for a physically much smaller
70-watt HPS ballast), though I don't know for certain if this was
actually the case. After several hours of apparently normal operation,
the lamp abruptly extinguished. At first I thought it was a power dip,
but the lamp still would not start even after about 20-30 minutes.
After a while, I opened the luminaire and looked things over. There
didn't seem to be any obvious signs of heat-related physical damage,
though there was a rather strong odor that seemed a fair bit stronger
than normal compared to my previous experiences with this stuff (though
I have no idea whether this would actually be normal or not). After
doing a few electrical continuity checks and after another hour or so, I
reassembled and carefully reapplied power for a few seconds. The lamp
then started and appeared to operate normally.
I'm sure there could have been another explanation, but I can't think
of anything else that seems particularly likely.
fixtures have?
