CDRIVE
I have no idea what you said but I think it translates to connecting the collector directly the Vcc and emitter to GND. If so there's no mystery why the transistor popped.That's great, thanks. Outputs 5.5v which is perfect for 3 - 6v motor. At first with your revision, I was frying yet another NPN until I decided to remove the connection between between collector and pin 8 (V+), thinking that putting 2 V+ connections to 1 collector wasn't a good idea. Then everything worked great.
Glad it's working now but it's time to trim the base resistor to a proper value for good saturation. The base resistor value is commonly calculated to provide 1/10th the collector current. So the first step is to measure the steady state current of your motor when connected directly to the battery.
Chris
