RobJ
I need to amplify a low-level 528MHz clock to an LVCMOS-level compatible
(i.e., 3.3V logic) single-ended clock. I have some control over the
low-level clock, but assume it's a 400mVpp sine wave. It is generated by a
Silicon Labs Si4133 synthesizer (IF output).
There are no LVTTL/LVCMOS buffers out there that can handle anywhere near
528MHz. I can get almost to the level I need using wideband transformers
from Mini-Circuits, but that causes large impedance changes across the
transformers and I still barely end up with 2Vpp. I would prefer an active
buffer using an Op Amp or transistor. The sine wave shape is not important
(i.e., a square wave output is fine), but I do need to preserve the duty
cycle as much as possible and minimize jitter. The system is nominally 50
Ohms (FR4 PCB traces) and the 3.3V clock load is a CMOS input buffer on an
IC.
Any suggestions would be appreciated.
Rob
IC.
Rob
