Hi, I'm having a problem when using a 4066 switch in my sample and hold circuit, when I used a mechanical SPST switch to test the S&H circuit when it was on the breadboard it worked great so I know there's nothing wrong with the circuit itself.
when I use the 4066 switch it seems to be leaking with nothing connected to the control pin, I tested with 3 different ICs and they all behave the same so im guess im missing something.
Any ideas what it might be?
Does the control pin need some sort of connection to ground maybe? (I read something about a 'pulldown resistor')
here is a schematic I made for the circuit:
![Untitled.png Untitled.png](https://makerv2.webteractive.co/forums/data/attachments/26/26649-4cee4b73c77bad20f92d49d7d772043a.jpg)
