4066 and audio
Do I need buffer ICs, or input caps or anything if I just want to switch mic level audio on and off with a 4066?
You must ensure that your audio signal is between Vss and Vdd (the power supply).
If the signal is generated by your curcuit, it will already be (most likely) between the supply rails, so it may be DC coupled to the 4066.
If the signal is coming from an external source, you may wish to have an input capacitor, and then bias the input of the 4066 at half the supply using a pair of high value resistors.
For similar reasons, you may also need an output capacitor (or not).
I don't fully understanding all you are saying, so please correct me if I'm wrong.
Vdd is 5v, and audio is guitar, or possibly line level, so all well under 5v.
By DC coupled, you mean direct, less the cap. What value is the norm for this AC coupling cap? Is a .01 disc cap acceptable for mic/line/guitar Z?
I don't really follow you on the biasing. Since the 4066 is just a switch, would I bias *only* to reduce clicks in the audio? If so, how do I do bias to 2.5v? Two resistors as a voltage divider to get 2.5v, on the IC side of the cap, and the audio input from the other side of the cap?
One circuit I saw uses 1meg to Vdd on the chip input, and then a 1 meg on the other side of the cap, at the input.
Thanks!
An audio signal is typcially going to go above and below ground. So the positive part of the signal may be < 5V, but the negative part is below 0, putting it out of range. The biasing brings the signal up to the midpoint (2.5V) when the signal is 0, so it allows the signal to go either positive or negative by 2.5V.
Bob
Bob
And the value in this is that I can put higher signal level without distortion?
no, it is so the switch will work over the full range of voltage swing in the audio. As bob said, right now the switch would be off for any voltage lower then ground potential, which is half the audio.
While I agree in theory about the negative waveform, in practice the 4066 seems to switch line audio just fine, unbiased. I have it working on a breadboard, so that's a bit confusing.
It seems easy enough to just add two resistors and and a cap to the input, and then a cap on the output, so I will.
I think line level is only about 2v, so with Vcc at 5v, I still have some headroom even after biasing to 2.5, yes?
A lot depends on what sort of 2V you have.
If it's 2V peak to peak, then you will have plenty of headroom.
2V RMS would be 5.7V peak to peak (for a sine wave) and that signal would be too large.
